Old 20-11-2004, 11:54 PM   #1 (permalink)
Default Can u shut down the pc by a timer ?
Is there a way using macros. etc to shut down the pc after a speculated time interval say 15mins or 1 hr etc . Much the same way a sleeptimer works for a TV or music system
rudra_chowdhury is offline
Old 21-11-2004, 12:07 AM   #2 (permalink)
why do u wanna use macros m8 ?
check this out
http://www.thinkdigit.com/forum/viewtopic.php?t=10250
there are more on this
and u get software to do it too
or u can create a new scheduled task to do this
No Mercy, No Limits.
theraven is offline
Old 21-11-2004, 01:38 AM   #3 (permalink)
There are lotz of software to shut down ur pc using timer.. But r u particular abt macro?
Here's one software.. Just 10 Kb..
http://www.pcplus.co.uk/downloads/de...ubsectionid=31
SmoothCriminal is offline
Old 21-11-2004, 04:04 AM   #4 (permalink)
well i use a software called aye shutdown pro....All i have to do is specify the time at which the PC has to be shutdown...and it does that..
www.ayesoftware.com
frostt is offline
Old 21-11-2004, 07:43 AM   #5 (permalink)
The Photoshop Guy
cooljeba's Avatar
Hi m8
check out this link
http://www.proffs.nu/Brutus_2004_Setup.exe
this software will allow u to shut down ur system with just one click and more like scheduling to shut it down later etc... it's around 1.1 mb.
And http://www.winutility.com/qsd/download/qsd.zip is around 506 kb
..:: peace ::..
Jeba
cooljeba is offline
Old 21-11-2004, 05:08 PM   #6 (permalink)
sujithtom's Avatar
I can create a TSR if you want for that...
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 21-11-2004, 05:18 PM   #7 (permalink)
aadipa's Avatar
http://yasoft.km.ru/eng/switchoff/ --- Only 64KB
Overview
Switch Off is a tiny easy-to-use tray-based system utility that can automatically perform various frequently used operations like shutdown or restart your computer, disconnect your current dialup connection, lock workstation, etc. It also provides fast access to this operations through system tray icon. Utility has fully customizeable Web interface, that allows you to initiate operations mentioned above remotely from any computer with web browser installed. Web interface includes WAP support, so you can control your computer from mobile phone. This utility is intended to be used by either novice or professional user, because of its intuitive interface and professional features.
Features
  Scheduled and immediate options for:
        Shutdown / Restart computer
        Log-off user
        Lock WorkStation
        Disconnect dialup connection
        Standby / Hibernate (power saving options)
        Fast restart (Windows 95/98)
  Customizeable Web interface (mini HTTP server)
  WAP protocol support.
  Simple intuitive multi-language interface
  Can work everytime when windows is running, even at logon screen.
  Command line support (including timer setings)
  Silent install option (good for run in a batch scripts)
  Works on all 32-bit versions of Windows (9x/NT/2000/XP)
  Tiny size and system resource requirements
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 22-11-2004, 09:14 AM   #8 (permalink)
h4ck3r
Posts: n/a
Default Shut down windows the kewl way
1)Press the windows key and r,
2)then type 'C:\windows\rundll.exe user.exe,exitwindowsexec'
3)Press enter ....then guess what
4)C the magic
If you want you can also create a shortcut for the same parameter using the "New-->Shortcut".(Right click on the desktop)
Old 22-11-2004, 10:56 AM   #9 (permalink)
if you are using winxp (or 2k but i am not sure) try "shutdown" command... anybody knows how to use it with at command
There are only 10 type of people in world...
1 who understand binary..
1 who don't
hitesh_hg is offline
Old 22-11-2004, 02:10 PM   #10 (permalink)
4)C the magic
wont that shut down the pc instantly ?
theraven is offline
Old 22-11-2004, 08:49 PM   #11 (permalink)
alib_i's Avatar
that's the aim!!
instant shutdown .. no mssges
similar thing for hibernation
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
-Metallica
alib_i is offline
Old 22-11-2004, 09:46 PM   #12 (permalink)
nono i meant it wont shutdown the pc after a given amt. of time ... it will instantly shut it down
the question is to shutdown the pc after a given amt. of time ..
theraven is offline
Old 25-11-2004, 06:10 AM   #13 (permalink)
alib_i's Avatar
hmm .ya raven . the topic is not abt instant shutdown ..
i was saying that hacker was aiming to shutdown instantly ..
other than that
you can try Banshee Alarm
Its a wonderful alarm .. can play media or run files at particular time
plus you can configure it to shutdown the comp at an alarm time
-Metallica
alib_i is offline
Old 25-11-2004, 12:17 PM   #14 (permalink)
ya its easy if u want a from other software then u get it
or u want to do your self then u know lang c? then write program to call rundll32.exe and compile prg then it make one object file & exe at the where the u set path from c editor/option/directory then run thet exe u immidiately shutdown or as u set
sheladiya chetan
chetan is offline
- by gohan89
