Old 20-11-2004, 11:35 PM   #1 (permalink)
Default HELP!! 50 second shut down error... really bugging
Hey Every1...
I got this really irritatin problem... whenever i connect to the net this message sayin "LSA Shell (export version) has encountered a problem" message appears and when i click 'dont send' another message saying my comp will shut down in 60 seconds appears... What the hell should i do...
HELP!!
<<-ShAuN->>
ShAuN is offline
Old 20-11-2004, 11:40 PM   #2 (permalink)
http://www.microsoft.com/security/incident/sasser.mspx
http://securityresponse.symantec.com...oval.tool.html
update ur antivirus and scan whole system after u have cleant this . there are lots of tips to protect ur pc in this forum . give them a good read through later
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 21-11-2004, 01:34 AM   #3 (permalink)
Dude search b4 u post.. See the Search link on top.!
SmoothCriminal is offline
Old 21-11-2004, 12:05 PM   #4 (permalink)
aha comeon, he probably dosent even know its sasser. You cant expect person who dosent know that there is something like this he wont be able to search
C2D E6600 L626A195 @ 3.42Ghz 24x7|Asus P5N32-E SLI|Crucial Ballistix DDR2 1000|8600GT|4x320GB Hitachi|SBlive 24bit|OCZ Gamextreme 700Watt PSU|Ultra 120 Extreme|Viewsonic VX2025WM 20.1'' widescreen LCD
funkymonkey is offline
Old 21-11-2004, 05:24 PM   #5 (permalink)
busyanuj's Avatar
when you get the 60 second message,
first go to Start Menu, click on Run and type shutdown -a in the window.
or the virus may not give you enough time to complete the download of the patch.
busyanuj is offline
- by gohan89
