Old 18-06-2006, 12:38 AM   #1 (permalink)
royal's Avatar
Unhappy Sql Server 2005 Versions
one of my friends has three iso files ...ia64,x64 and x86 versions of Enterprise edition of Sql Server 2005...
now which of these three can be installed on Win XP Pro ?
ia64 is probably for Itanium processors and x64 for XP 64 Bit... so is it the x86 version
royal is offline
Old 18-06-2006, 02:20 PM   #2 (permalink)
royal's Avatar
Red face Re: Sql Server 2005 Versions
c'mon...no one ?
are all of you guys and gals so much in love with your Sql Server 2000 version
royal is offline
Old 19-06-2006, 01:45 AM   #3 (permalink)
18 Till I Die............
Default Re: Sql Server 2005 Versions
It should be x86 if you have a 32-bit system. BTW, google could always have helped you there.
BTW, I don't use MS-SQL. Why would I when I have a better alternative in MySQL and I don't need to either pay for it or pirate it. And it gives better performance.
mehulved is offline
Old 19-06-2006, 10:37 AM   #4 (permalink)
royal's Avatar
Smile Re: Sql Server 2005 Versions
thx for your help...anyway I had figured it out myself
and no, google could not provide me the answer.It came up with the enterprise,developer,express etc. versions...maybe i could not search properly
royal is offline
Old 19-06-2006, 12:19 PM   #5 (permalink)
Cos you were searching google for wrong query. I mean you should have googled for x86, x64 and ia64. That would have explained you what these three terms mean.
mehulved is offline
- by gohan89
