Old 17-06-2006, 04:17 PM   #1 (permalink)
Default virtual memory is low ?
hi
i m getting always this error........virtual memory is low
......what should i do..........
how to change virtual memory settings ?
mkmkmk is offline
Old 17-06-2006, 10:19 PM   #2 (permalink)
Your Maker.
MysticHalo's Avatar
Default Re: virtual memory is low ?
Run>sysdm.cpl>advanced tab>performance settings>advanced tab.
There, in the virtual mem. section, increase mem so that it the minimum virtual mem is twice the physical memory(RAM) and max is approx 3 or more times ur RAM (depends on ur HD space)
BUt this wont help much...the mentioned error occurs mainly when u run intensive apps in RAM-deficient machines. Consider increasing ur RAM.
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 17-06-2006, 11:07 PM   #3 (permalink)
ashisharya's Avatar
1. Click Start, and then click Control Panel.
2. Click Performance and Maintenance, and then click System.
3. On the Advanced tab, under Performance, click Settings.
4. On the Advanced tab, under Virtual memory, click Change.
5. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to select the System managed size check box, and then click Set.
7.Click OK three times.
When you are prompted to restart the computer, click Yes.
hope this will work
source:http://support.microsoft.com/?scid=kb;en-us;837869
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 18-06-2006, 01:11 AM   #4 (permalink)
JGuru's Avatar
Just increasing Virtual Memory won't solve your problem. You have not specified the RAM - whether it is 128 , 256 MB. Windows XP needs 256 MB RAM for good
performance. Also take into consideration how many programs are running at the
same time. If you open too many programs it will consume too many resources.
Also try freeing the memory by using RamBooster. Get it here :
http://www.download.com/RAMBooster/3...ml?tag=lst-0-1
It will surely help to free the resources.
JGuru is offline
Old 18-06-2006, 11:34 AM   #5 (permalink)
slugger's Avatar
i don't disagree with what u say. but it may so happen dat his virtal memeory has indeed been set very low. I got 512 MB of RAM. Somebody using my computer d other day fiddled with it and set it to less than 100 and i strted getting the same mesage. All i did was increase the Vitual memeory to an apropriate value and the message stopped coming.
So my friend b4 going 4 a RAM upgrade, just follow the methods given above to increase ur virtual Ram and see if the problem disapears
slugger is offline
Old 19-06-2006, 11:58 AM   #6 (permalink)
upss sorry for incomple information........
i have 256 mb ram...40 GB HD........then how much i sould keep as v memory....
tell me perfect figure.......
minimum virtual mem is twice the physical memory(RAM),,,as per this suggestion i should make custom size.....256.....? correct me ......
mkmkmk is offline
Old 19-06-2006, 01:39 PM   #7 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
keep it at 512MB min amd 1024MB max
Rollercoaster is offline
Old 19-06-2006, 09:03 PM   #8 (permalink)
I have disabled virtual memory as an experiment and there has not been any problem for the last few weeks since I did so.
I have Win XP updated, Open Office, Avast, Spybot etc. And usually i dont run more than one or two programs at a time. Most of the time more than half the memory is free.
BTW I have 1GB.
V.Prem Kumar
janitha is offline
- by gohan89
