Old 20-11-2004, 07:34 PM   #1 (permalink)
Default Tell me how to do this..??
how U all write this ...??
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 20-11-2004, 07:36 PM   #2 (permalink)
i think after you become resident techie you are allowed to add caption above your avatar
ironcross77 is offline
Old 20-11-2004, 07:37 PM   #3 (permalink)
din
Tribal Boy
din's Avatar
Thats ranking based on the number of posts in this forum , and the second line , I think its a part of his avtar.
din is offline
Old 20-11-2004, 07:38 PM   #4 (permalink)
vysakh's Avatar
i think that is a part of the avatar
Incompatible message format
vysakh is offline
Old 20-11-2004, 07:38 PM   #5 (permalink)
you got it right din
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 20-11-2004, 07:54 PM   #6 (permalink)
welcome to forum yehmeriidhain
...now u know the secret...so go about it..!!!!
atool is offline
Old 20-11-2004, 08:00 PM   #7 (permalink)
Dude.,. and was that ur first post?!
SmoothCriminal is offline
Old 20-11-2004, 08:26 PM   #8 (permalink)
People actually i'm a student & we too have forums on our institute website & i need to put the same thing above my avatar therre tht's Y tell me ...i know here it's the number of post tht matters but how to do it in my institute's forums plzz help me there .......... do help ..
Well yes !! this is my 2nd post
Old 20-11-2004, 08:31 PM   #9 (permalink)
Dude.. r u gona create/design a forum from scratch?.. It means its gona be really tedious... why dont u go for go and download forums from www.phpbb.com and such sites?.. they're really easy and can be customised easily....
Old 20-11-2004, 08:33 PM   #10 (permalink)
Well.. it seems like u're already running the forum.. then its a simple IF Conidtion block na? Depending on the no of posts u gota print watver u desire to be printed..
Old 20-11-2004, 08:43 PM   #11 (permalink)
Try tis out too : http://www.phpbbhacks.com/
Its a famous site but Just if u dint kno.
beyondthegracefgod is offline
Old 21-11-2004, 12:14 AM   #12 (permalink)
well the links were good but still not so helpful & mind U i'm not running a forum i'm just a member in thr ... i asked people belonging to admin they said try it & do it on ur own i tried but all in vain tht's Y posted in here ....
Well here admin of digit can U help me somewat??
Old 21-11-2004, 04:53 AM   #13 (permalink)
Tell me anyone, where do I get a NICE previewer for php files on my computer.
I am the old sonuchandrakar of this forum, but with a new ID, forever. Check out [url]http://www.zonearea.com[/url]
Nighthawk is offline
Old 21-11-2004, 09:43 AM   #14 (permalink)
NikhilVerma's Avatar
Default Re: Tell me how to do this..??
Well If his post gets into the blue region you'll automatically see the difference...
NikhilVerma is offline
Old 21-11-2004, 12:47 PM   #15 (permalink)
No nikhil its no more like that, you can see it
Old 21-11-2004, 01:15 PM   #16 (permalink)
Create a new image in a photo editing application, with a transparent background, and write the text on top!
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 21-11-2004, 02:52 PM   #17 (permalink)
I dunno how to make U all understand this small thing ........ plzz try to understand i don't wanna see the change up my avatar due to the number of posts instead i wanna put sth of my own like : POPE ...
Tell me how to do tht... plzzz...
Old 21-11-2004, 03:02 PM   #18 (permalink)
Do you have GIMP or photoshop or something? Ask Jeba or Dexter, they might give you detailed instructions ...
ujjwal is offline
Old 21-11-2004, 04:32 PM   #19 (permalink)
look dude
if u want to replace where it says resident techie or digitised
u cant
that depends on ur post count
if u wanna add to it ... u can have that written on ur graphic
what u will need to do is create a GIF ... write what u want there for eg technoteen wrote "geeky teen" then make the background of the GIF transparent
u can do it in any image editing softare like jasx paint shop pro or adobe photoshop
this writing will be part of ur avatar but will look like a part of ur status as it does with technoteen
No Mercy, No Limits.
theraven is offline
Old 21-11-2004, 07:37 PM   #20 (permalink)
No...
I'm saying that the post columns are appearing with swapping colors like white,blue,white,blue....
So If you post lands into the blue zone ... then the difference will be seen....
Old 21-11-2004, 08:48 PM   #21 (permalink)
theraven is offline
Old 21-11-2004, 09:22 PM   #22 (permalink)
well. he's not clear wid his question.. but i guess its abt transparancy!.. it seems more like he's asking how to get the 'digitized!' in his college forum!
Tell me how to do tht... plzzz... Sad
Not sure if we are all Not understanding or u r unclear!?! Huh
@yehmeriidhain
Dude it is how this forum had been programmed in PHP.. You can put that tag, i mean 'digitized' etc based on no of posts, only if u know PHP programming... (I take it as ur current forum doest support ths feature as of now).. There's no other way of setting 'Options' kinda so that u can show that..
Old 21-11-2004, 10:08 PM   #23 (permalink)
OK! OK! now i think i'm getting the responses which i wanted ...
For sure!! the transparent background is not a solution...
I think i need to know PHP & need to have some sort of powers to access the existing code ....
Actually in my institute some of our students has put siteadmin & Pope: religion ..from their 1st post mind U ... so it's just tht doesn't depend on number of posts ... here although the case is different .... in this forums this is ofcourse the number of posts in here......
& Mr. smoothcriminal i'm very sure of my question the thing is i was feeling like i'm not able to make u ALL understand this small thing... but now i have got a reply tht it is sth programmed through phpbb which i dunno still enough thx! to U all for teaching me sth which i never did... Thx!
- by gohan89
