Old 20-11-2004, 01:34 PM   #1 (permalink)
bipin_hbk
Posts: n/a
Default Bios Upgrading.....
Dear Friends
I want to upgrade my bios. I am Posting the current bios specification of my bios. Pls. can Anyone guide me how get the newer upgrade for the same and how to flash it. If possible from windows itself. I wanna flash since it is not supporting no. of things including my 120 gb hdd. Pls. help!!!!!
Program: eSupport.com BIOS Agent Version 3.41
BIOS Date: 08/22/02
BIOS Type: Phoenix-Award BIOS v6.00PG
BIOS ID: 08/22/2002-P4M266-8233-6A6LWJ19C
OEM Sign-On: V.P4MFM A05 08-22-2002
Chipset: VIA 82C3148 rev 0
Superio: Winbond 697HF rev 6 found at port 2Eh
OS: WinXP SP2
CPU: Intel Pentium(R) 4 1700 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 768 MB
Memory Slot 01: 256 MB
Memory Slot 02: 0 MB
Memory Slot 03: 0 MB
Old 20-11-2004, 04:37 PM   #2 (permalink)
go to the web site of the mb manufacturer and download the bios updates of your board.
as far as supporting 120 gb hard drive
-if this is the new hard drive you've buyed make it slave
boot windows XP
-right click on my Computer
-select [b]Manage[b]
-choose disk manager
this will show you the right capacity of your drive and here you can safely create partitions
after this you can use your hard drive properly
Matrix_neo is offline
- by gohan89
