Hi
I recently purchased the game nfs most wanted.The problem is ,the game doesnt run very smoothly on my comp.I've got a p4 2.8 ghz processor,512mbram,and a intel d101ggc motherboard.Is my pc configuration the cause of the game not running smoothly?WIll increasin the ram to 1gb help?
Somedays you\'re the dog,
somedays you\'re the hydrant.
The IGP is too underpowered to rum NFS mostwanted at mid settings...so just lower the setting and u will get better frame rates..
But if u want to play games at high settings with good frame rates u will have to get a new gfx card...........
when i checked my sys config using dxdiag,it said i had a ati radeon 2000 series onboard card.Now,xcuse my ignorance here,but shudnt a 256 mb card be gud enuf,even though its an onboard one?
Well .. if ur onboard has a shared mem. of 256 MB .. then ur system ram should be 256 MB too ( if u have a total of 512 MB ram) ... so u really cant expect the game to run anywhere close to smooth at all ...
Also .. onboard solutions are really not good enough .. why do u think do we use add-on gpu's ???? Simply because putting in more onboard solutions puts additional tasks on the cpu .. and introduces loads of latency ....
Who said anything about your onboard graphics having 256 MB? 256 MB is just the memory that is taken from your system by the onboard graphics. You can increase it to 2 GB and it still won't have any effect unless the graphics core is powerful enough.
Even in a dedicated video card, the core speed matters much more than the amount of memory present.
