Old 16-06-2006, 11:47 AM   #1 (permalink)
the deconstructionist's Avatar
Default Add Remove problem
The Game american army cannot be unistalled from add remove . Using Xp. Please heip. Thanks in advance.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 16-06-2006, 12:05 PM   #2 (permalink)
JGuru's Avatar
Default Re: Add Remove problem
Try uinstalling it in safe mode. If that also works try this. Install Mandriva Linux 9.1 or
higher. You can access all Windows partitions , including NT partitions. To access C
drive type '/mnt/win_c' in Konqueror(KDE). Go to the folder where American Army is
installed and delete it!! That's all it will get deleted 100%. ZoneAlarm Pro used to
give me the same problems, and I deleted it this way!!
JGuru is offline
Old 16-06-2006, 01:52 PM   #3 (permalink)
champ_rock
champ_rock's Avatar
deleting the folder DOES NOT remove the game completely.. there are registry files etc. which are still left..
what error does it give when u try to uninstall it?? maybe that will help/
Registered Linux user number 400618
champ_rock is offline
Old 16-06-2006, 01:59 PM   #4 (permalink)
samrulez's Avatar
Did u install the games or was it compressed and u just extracted it? Are u getting any error messages??
Sam :D Rulez :lol:
samrulez is offline
Old 18-06-2006, 01:46 AM   #5 (permalink)
__Virus__'s Avatar
if I were you.. I wud delete all the folders and use a registry cleaner and it will help me.
__Virus__ is offline
Old 18-06-2006, 07:07 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
If it has an entry in Add/Remove, simply delete the game folder and then click uninstall, it will erase the entry after an error and clear up a bit of its entries too...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-06-2006, 08:55 AM   #7 (permalink)
Distinguished Member
anandk's Avatar
enter safe mode
install the game again in the same folder.
then try to uninstall it.
u may have to reboot...
if it dznt work, again go to safe mode and delete all the programs folder.
then use a good junk/registry cleaner to clear pc junk.
try this one www.ccleaner.com
u can also use it to remove invalid entries from ur 'addremprogs'.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-06-2006, 09:08 AM   #8 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
try one simple thing.. go to the installation folder and look for uninstaller files like uninstall.exe or setup.exe or something similer..
this usually works for such problems
Rollercoaster is offline
- by gohan89
