Old 20-11-2004, 01:02 PM   #1 (permalink)
Default Problem! Please help
I have a problem in browsing internet. That is some basic sites like yahoo, google, gmail etc., are not opening , automatically it goes to a search page menting the domain is available for sale. It happens in both IE and Opera. I thought software would have been installed and i found many search softwares installed unknowlingly. So i removed all of them but i still have the problem. i dont know what to do? Kindly adviceme
Flowers say pluck me not,
Grasses say stamp me not,
but i say,
Forget me not.
senthilrek is offline
Old 20-11-2004, 02:39 PM   #2 (permalink)
Bewitched!
xenkatesh's Avatar
Try this go to the internet option in IE and set the home page to www.yahoo.com save it now check it again!!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 20-11-2004, 02:41 PM   #3 (permalink)
kl_ravi's Avatar
I think your computer is infected with spywares and browser plug-ins. Download Spybot S&D to weed out all your problems...
http://www.safer-networking.org/en/download/index.html
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 21-11-2004, 12:24 AM   #4 (permalink)
The easiest solution? Dont use IE. Switch to Firefox or Opera today!
Download links in my signature..
_________________
Firefox
Rediscover the web
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 21-11-2004, 12:46 AM   #5 (permalink)
Originally Posted by [deXter
]The easiest solution? Dont use IE. Switch to Firefox or Opera today!
_________________
Firefox
Rediscover the web
m8 he already said that he is using opera and geeting the same problem
it think you have spyware problem, use spybot or system mechanic
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 21-11-2004, 01:22 AM   #6 (permalink)
whoops! My mistake
senthilrek, please try CWShredder and see if that solves your problem.
Then check your C:\Windows\System32\drivers\etc\hosts file. Open it in notepad. Ignoring the '#' lines, there should only be one like like this: 127.0.0.1 localhost. If there are additional lines, delete them and add this.
Now in both Opera and Ie, check your proxy server settings. Disable any proxy servers if used. In opera, Tools -> Quick Preferences-> Enable Proxy Servers (uncheck if checked).
If all that doesnt work, then you'll need to download Spybot Search and Destroy like everyone says. Install, update scan and destroy
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 21-11-2004, 09:23 AM   #7 (permalink)
ice
Damn, i was about to tell him to check his host file and run cw shredder
ice
ice is offline
Old 21-11-2004, 01:39 PM   #8 (permalink)
Could be the hosts file as DeXter says ... anyway on windows 98 the hosts file if present will be at C:\Windows and C:\WINNT\SYSTEM32\DRIVERS\ETC for Win 2k ...
If nothing works post your HijackThis logfile - http://www.spychecker.com/program/hijackthis.html
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 21-11-2004, 02:25 PM   #9 (permalink)
Your comp is infected by spyware obviously.Use hijackThis and post the log here. Or better download and run Spy Doctor Trial
http://www.pctools.com/spyware-doctor/
ironcross77 is offline
Old 21-11-2004, 05:01 PM   #10 (permalink)
sujithtom's Avatar
I think your computer has a spy ware. Remove it using Ad-Aware. Mention the search site for further help.
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 21-11-2004, 09:55 PM   #11 (permalink)
More replies from the forum memebrs and mods.But there is no reply from "senthilrek"
My Trip had been cancelled.So I will be here with you .
-Lavan joy@Lavan_joy since Dec 2003
lavanjoy is offline
Old 23-11-2004, 09:15 PM   #12 (permalink)
Than for ur replies. I have mentioned whether some one posts some replies mail me to my gmail address. Since gmail wasnt working in my system i was not able to see ur messages. Ok today i have logged directlty to thindigit forum. i happy to see a lot advices. i will try them today and i will give the feedback tommrow. Sorry for keeping u people waiting.
Thanx
but i say,
Forget me not.
Old 26-11-2004, 09:56 PM   #13 (permalink)
@ dexter. your sig is gr8. Wat else can M$ says when it knows no one is going to even look at IE now.
Don\'t assume. It makes an ASS out of U and ME
tushar_novice is offline
- by soumya
- by tv6952
