Hi
I will be purchasing a new DVD RW and another UPS shortly. My configuration is as follows :
Intel 915 GAV Motherboard
Intel 3.0 GHz CPU HT
Samsung MagicBright 17" Monitor
Samsung 160 GB HDD SATA1 7200rpm
Lite-On DVD Rom 16X
LG CD RW 52X
Hynix Zion 512MB DDR 400MHz
Canon xnu i255 Printer
Creative Inspire 5.1 5200
Creative Live 7.1 24-bit Sound Card
Pinnacle PCTv Pro TV Tuner
BPE 600VA UPS
The 600VA UPS can't give me enough backup, so I wanna go for a new UPS
It will supply power to -->
1) 17" Monitor
2) 5.1 Speakers
3) Canon Inkjet Printer
4) ADSL Modem
5) CPU
So the question is what UPS I should go for
A) APC BACKups 650 VA
B) Numeric 800VA
Tell me which one (or any others if u suggest)
2nd thing is that my Power supply is a mere 300Watt Frontech one
Do I need to change it prior to installing a DVD RW ?
If Yes do tell me what sort of a power supply should I go for ?
