Old 14-06-2006, 12:11 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Arrow How To Lock Your HomePage.
This tip will keep other users,spyware, and websites from changing you
IE's homepage. It is best to set your start page as about:blank.
1. Click on the Start button, select Run and
type in 'regedit'
2. Look for this string:
HKEY_CURRENT_USER\Software\Policies\Microsoft
3. Right-click on the Microsoft folder, select
'New->Key' and name it 'Internet Explorer'
4. Right-click on the Internet Explorer folder,
select 'New->key' and name it 'Control Panel'
5. Right-click on the Control Panel folder,
select 'New->DWORD' Value and name it 'Homepage'
6. Right click on the Homepage value, select
'Modify' and change the value from '0' to '1'.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 14-06-2006, 12:43 PM   #2 (permalink)
nik_for_you's Avatar
Default Re: How To Lock Your HomePage.
this is question answer section . i think this thread is for tutorial section or like that..
I AM REBEL
nik_for_you is offline
Old 14-06-2006, 07:49 PM   #3 (permalink)
anandk's Avatar
my error in posting. pls shift there.
Microsoft® MVP
anandk is offline
- by gohan89
