Old 27-07-2004, 06:23 PM   #1 (permalink)
Default Is the 2.8C P4 with 800FSB/HT available in India?
Hi,
I'm new to the forums. I am planning to get a new system over the next week or two. I want a Northwood P4. The H/w price list put up on these forums as well as a Delta Peripherals price listing i saw someplace does not mention a 2.8C 800FSB/HT processor. Is this available in India? The price?
Another q. Given the above processor, what would you guys suggest for a good(-to-great) Mobo? I want to overclock good
tia
vv
vinodv is offline
Old 27-07-2004, 06:43 PM   #2 (permalink)
I think you can find it.It is for 9k.
Also,rather go for amd 2800 64 which is 500-700more but is a bit better @ gaming and tis said that after release of 64bit windows the performance will increase by 20%.It also has 64bit functionality.
2.4c can be oced to 3.6
Also easily 2.4c can oced to 3.2 with ease.
akshayt is offline
Old 27-07-2004, 07:02 PM   #3 (permalink)
Thanks for the reply.
I'll consider the amd64.
I really would like to overclock my CPU to around 3.5. Hence my choice of a 2.8C. Do you think a 2.4C will go upto 3.6 on air/stock cooling alone? What cooling soln. available in India will I need otherwise?
And the motherboard?
tia
vv
vinodv is offline
Old 27-07-2004, 08:54 PM   #4 (permalink)
No way u r gonna do 3.6 with a 2.4 with stock air cooling. U'll need water based cooling. And yeah rather than going for the 2.8 go for a AMD 64 which runs very cool and hence is more suitable for overclocking. And yeah finding a northwood 2.8 might be a bit if an exercise.
Btw u can cool .....umm thats not the correct word.......ok freeze ur processor to sub zero temps using liquid nitrogen based cooling or refrigeration. Then u might be able to achieve 4Ghz+ with ur 2.8Ghz.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 28-07-2004, 02:13 PM   #5 (permalink)
amd 64 isn't much ocable but amd 2800 should be able to make amd 3200.
akshayt is offline
Old 28-07-2004, 02:55 PM   #6 (permalink)
Default Cost
What does the A64 3200+ cost in India?
Between the A64 and the 2.8C which one is more ocable?
-vv
vinodv is offline
Old 28-07-2004, 06:50 PM   #7 (permalink)
A64 cost 14k approx. Dunno abt ocing rates or % however. But i wudnt base my buying decision on overclocking performance.
Old 28-07-2004, 06:56 PM   #8 (permalink)
wait for 939cpus to lower the prices,arriving in 2months,quite likely.
akshayt is offline
Old 30-07-2004, 09:04 AM   #9 (permalink)
aadipa's Avatar
64 bit windows isn't out yet ??
i saw one cd at my friend's place, but it don't even start setup on 32-bit CPUs like P4s and Athlon XPs
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 30-07-2004, 09:56 AM   #10 (permalink)
No the 64 bit Windows XP isn't out yet. And how do u expect a 64 bit Os to even start set-up on a 32 bit machine.
Old 01-08-2004, 12:32 AM   #11 (permalink)
aadipa's Avatar
It was 64 bit Win Xp for sure..
and i want to try it on my 32 bit AthlonXP..
aadipa is offline
Old 01-08-2004, 12:45 AM   #12 (permalink)
aadipa's Avatar
may be VMWare will help me
aadipa is offline
Old 01-08-2004, 03:39 PM   #13 (permalink)
windows xp 64 bit is out for evaluation
not launched yet
not sure if u can use even vmware to simulate a 64 bit os on a 32 bit comp....
lemme know if it works
No Mercy, No Limits.
theraven is offline
- by gohan89
