| Forum |
#1 (permalink) |
HELP AND SUPPORT
Hard Drive Mechanic is the best hard drive data recovery software available. It fixes 99% of hard drive data recovery problems.Hard drive failure is very upsetting because your hard drive holds all your valuable data files. You could send your hard drive out for repair. But then you have to remove it from your computer or transport your computer to a repair site. This takes time and can be expensive. Also there is no guarantee that your hard drive data will be recovered. OK after this opinion u think why not try it...yes u can try as there is a free trial download ...as its a shareware u hav 2 pay 69.97$ ..any1 can say their opinion after reading and trying it out |
#4 (permalink) | |
HELP AND SUPPORT
There r lots of software which r free which recover deleted and corrupted files .....but this 1 recovers ur files from a hard drive which is scrwd badly...which means if ur hard drive is crashed and there r no chances of getting back ur data then this software is the only solution and there r no competetors to this really gud worth buying software... |
#5 (permalink) |
i understand that their many software that can recover files but i want to know that can this software retain the original name of the files. Does it has support of all types of files or some files like mp3, doc etc.
We must accept finite dissapointment. But we must never loose infinite hope. Last edited by sourav; 14-06-2006 at 06:47 PM. |
#7 (permalink) | |
HELP AND SUPPORT
Sorry 4 da late reply but this software can retain the original file with its original size,name and its exact properties....There is no particular file extension 4 dis software ..It recovers any kind of file....FOR MORE INFO VISIT www.highergroundsoftware.com |
#8 (permalink) | |
HELP AND SUPPORT
#9 (permalink) |
Rakeshishere - i've downloaded a copy of the evaluation version. file name mechanic.exe, how do i use this to run on my pc that a problem with "disk boot error, insert system disk and press enter" do i just copy this file to a floppy disk and insert it to a pc and then reboot or do i have to make the disk bootable? Pls reply asap.
#10 (permalink) |
There is also a product from Ontrack called 'Easy Recovery ' . OnTrack is the market leader as far as
data recovery is concerned. It supports Win 9X, ME, 2000, XP, Linux, Unix, SCO Unix, Sun Solaris, Mac, OS/2, VAX/VMS. There is also 'Remote Data Recovery' software available. You bet OnTrack is the best. |
#11 (permalink) | |
HELP AND SUPPORT
| Bookmarks |
| Display Modes | |
