Qwerty i don't think u can play avi files in vcd players. You have to first convert the ogm file to mpg-1(vcd format) file format. U can use this software to do it http://www.tomdownload.com/multimedi..._converter.htm
By the way don't you think that MovKit Batch Video Converter. is a bit too slow ? Doesn't it take as long as 4 hours to finish converting a one and half hour movie to VCD format in a 2.4 Ghz machine ? So,anything else that anybody knows ?
well, to be frank i haven't tried any software for the problem you have put forward. Nways i have googled for the conversion software but it seems there aren't much software for the purpose. But if i find a better one, wud b glad to tell you.
