Old 12-06-2006, 01:07 AM   #1 (permalink)
Default partition Magic problem
recently i bought Compaq Presario laptop..
with Windows XP Home Edition and NTFS File system
it has 60gb harddisk.. with no partition.. only C: drive..
i tried to make partition with Partition Magic 8.0
first i create 2nd partition of 20Gb.. is work ok and partition created successfully.. but when I tried to create 3rd parttion it not creating any partition..
wheni chacked partition (c:\ drive) for error.. i m getting error asfollow..
"Error # 993 Partition contains open files. Use operating system check utility"
also i tried to create partitionin safe mode assuming some process running that are creating problem.. but in safe mode i get same message..
now wht can i do to solve this problem... help plz...
Ravi-the Sun
Think Bright,Think Sun
www.ravithesun.c-o.in My Blog
www.sunsoft.c-o.in My Web Home
ravimevcha is offline
Old 12-06-2006, 12:43 PM   #2 (permalink)
JGuru's Avatar
Default Re: partition Magic problem
Which harddisk you are using Seagate, Western Digital, SamSung, Hitachi, Maxtor.
Every harddisk manufacturer has his own harddisk partition & diagnosis utlity. I have a Seagate HDD. I use Seagate's DiskWizard Starter Edition CD for partitioning and it does partition & formatting in few seconds!! Send me a PM about the HDD you are using and I'll tell you how to go about partitioning your HDD. Don't use Partition Magic!!
JGuru is offline
Old 13-06-2006, 12:34 AM   #3 (permalink)
well.. i have Compaq Presario laptop it has Fujitsu's harddisk..
plz tell me how can i create partition in this hardisk..
Ravi-the Sun
Old 14-06-2006, 12:11 AM   #4 (permalink)
plz help me guys.. how to solve this problem..
Ravi-the Sun
- by gohan89
