Old 11-06-2006, 07:57 PM   #1 (permalink)
Default pc temp issues
hello all
i am facing very different problem in my pc as in normal use the temperature is around 50 to 53 but as soon as i click small exe game or application except msn yahoo temp reached 70 to 80 in 2 seconds please suggest what to do i am facing this problem from last 3 days i chekced all cables and fans all working fine even thermal is fine please help my config
intel3.0 ghz ht
865gbf intel mobo
1gb 400mhz ram
ati9800 pro
thx
hunk_freak is offline
Old 12-06-2006, 10:44 AM   #2 (permalink)
Default Re: pc temp issues
keep cabinet spacious n open for 2-3 days n then check temp again n see if increses or not
NagpurDaMunda is offline
Old 12-06-2006, 12:05 PM   #3 (permalink)
JGuru's Avatar
It's very strange!! If your fans are working fine then how come the temperature shoots to 80. If you are playing high-end games then definitely the temperature will shoot up. But it should not shoot-up during normal web browsing or other less
CPU intensive applications.Make sure your cabinet is well-ventilated.
JGuru is offline
- by gohan89
