Old 11-06-2006, 02:28 PM   #1 (permalink)
Default Connecting Lappy n Desk
I have got a desktop ( AMD Athlon XP 2000+ , Asus motherboard ) with a Dlink ethernet card and also an IBM Laptop also with an ethernet card.
I also have a 2 way LAN cable ( i,e the one provided with DATAONE Modem).
Is it possible to connect the Desktop and laptop thru this cable ???
and wht are the IP settings i shud do ?
( i wanna play AOE in multiplayer mode via all this......... )
~:::::everything that has a beginning has an end:::::~
adi87 is offline
Old 11-06-2006, 05:10 PM   #2 (permalink)
samrulez's Avatar
Default Re: Connecting Lappy n Desk
1st hook up the cable and enter the IP in 1 one system as 192.168.1.1 and 192.168.1.2 in the other and u will be done.....
To be able to share files and access other drives..
Right click on the drive and enable sharing.....ad u will see a hand under each drive........
Sam :D Rulez :lol:
samrulez is offline
Old 11-06-2006, 11:36 PM   #3 (permalink)
Hey the problem is tht i get the message
The network cable is unplugged.....
please help me with this........
adi87 is offline
Old 12-06-2006, 08:15 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ That's because you need a cross cable, not the straight cable provided by dataone.
kalpik is online now
Old 12-06-2006, 08:41 AM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
whats the diff in cross over cable & straight cable
gary4gar is offline
Old 12-06-2006, 11:31 PM   #6 (permalink)
String Phreak
mediator's Avatar
The difference is straight cable is just a bunch of 2 or more cables in which the start and end of the wire connect to the same segment like read port of one pc to read port of another pc!
A crossover on other hand has the wires connected in a crossover manner like wire connecting read port to write port etc. Thats why it is also called a null modem.
mediator is offline
Old 13-06-2006, 12:05 AM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
thanx for info man
gary4gar is offline
Old 14-06-2006, 12:08 PM   #8 (permalink)
Yeah....thnx from me too....
Wht will be the cost of this cross-cable ?????
adi87 is offline
Old 14-06-2006, 01:47 PM   #9 (permalink)
You'll get that cable for not more than Rs50. Just buy a cable and do as samrulez said above.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
- by gohan89
