Old 10-06-2006, 02:17 PM   #1 (permalink)
Default hdd doubt...
hi
i am planning to buy a 160gb ATA hdd 7200 rpm.......
my motherboard is an apoen one with the via kt133 chipset......
will my motherboard support the hdd?
if it doesnt.......upto wat capacity will it support....
want the answer urgently....as hv to make the buying decision soon,...
simoncherian is offline
Old 10-06-2006, 05:11 PM   #2 (permalink)
JGuru's Avatar
Default Re: hdd doubt...
You have not mentioned whether it's SATA or PATA. Check whether your
motherboard supports SATA. Your Windows OS will be able to detect only 137 GB!! To overcome this you need to install Service Pack I & II for XP.
And you can install SP for XP if it's a genuine one!! Linux doesn't have any
limitations. You can go for Western Digital or Seagate.
JGuru is offline
Old 11-06-2006, 07:15 PM   #3 (permalink)
the motherboard doesnot support SATA drives......only the PATA ones
(i am assuming the pata ones are the ones which are connected lk the cd drives)
Old 11-06-2006, 07:41 PM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
yes u r write.. pata cables are much broader then sata cables
Rollercoaster is offline
Old 12-06-2006, 12:17 AM   #5 (permalink)
MegaD3th3K's Avatar
wat is SATA, PATA, ATA?
MegaD3th3K is offline
- by gohan89
