Old 18-11-2004, 11:40 PM   #1 (permalink)
g_goyal2000's Avatar
Default Nokia PC Suite
I have Windows 98 SE installed as OS on my computer.
I recently installed "Nokia PC Suite v5.62" on my computer. After installation & restarting the computer, the PC Suite created it's own system folder in "My Computer" named "Nokia Phone Browser". After sometime, I uninstalled the PC Suite using it's own uninstaller.
The problem is that after uninstallation & restarting the computer, "My Computer" still shows a system folder but without a name. I can't either access it or delete it. If I try to create a shortcut to it, it shows me a message that "Windows could not create the shortcut. Check to see if the disk is full."
I even reinstalled the PC Suite & restarted the system. The "Nokia Phone Browser" system folder came back in place of blank system folder in "My Computer". But after uninstalling the PC Suite, the blank system folder again came back in place of "Nokia Phone Browser" system folder in "My Computer".
I want to remove this unnamed, inaccessible & useless system folder from "My Computer" & I don't want to format my hard drive.
Kindly help.
Gaurav Goyal
g_goyal2000 is offline
Old 19-11-2004, 11:51 AM   #2 (permalink)
tuxfan's Avatar
Do you know DOS commands? Are you comfortable with them? If yes, you can restart in command prompt and delete the folder after changing its attributes. It may not work. But you can try.
If you are not comfortable with DOS commands, I will try to give you a step by step guide on how to do it.
tuxfan is offline
Old 20-11-2004, 01:18 AM   #3 (permalink)
sms_solver's Avatar
@tuxfan, DOS will not going to help g_goyal2000,
he is not talking about real system folders, he is talking abt the folder like icons that appear in MyComputer like DailUP
@g_goyal2000,
it can be delete it using registry editor! If you want detail then I can help you
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 20-11-2004, 02:19 PM   #4 (permalink)
tuxfan's Avatar
You may be right. Let wait for his feedback.
tuxfan is offline
Old 20-11-2004, 06:00 PM   #5 (permalink)
Thanx sms_solver.
You understood my problem & what I meant.
I would like to know how I can delete the folder.
I'm comfortable with registry editing or any other system modification.
Please help me.
Old 22-11-2004, 01:00 AM   #6 (permalink)
sms_solver's Avatar
Right now I don't know exact location
but you can go
to
My Computer\HKEY_LOCAL_MACHINE\Software\Microsoft\Win dows\CurrentVersion\Explorer
Within Explorer Seach for Namespaces, find string like Nokia...
remove it, it might help
you can try!
[ॐ एसएमएस॰सोल्भर ॐ]
Old 22-11-2004, 05:55 PM   #7 (permalink)
Thanks sms_solver.
U solved my problem.
I found the string.
Thanks a lot.
- by soumya
- by tv6952
