Old 18-11-2004, 08:44 PM   #1 (permalink)
Default Security code in 3315
Hi.. guys..
I have a 3315 nokia.. i was using it a year back.. but again i have to use it for my other connection, but when i inserted new sim .. it asked for Security code (the 5 digit code specific to phone, not related to sim), but i forgot that.. so my old sim is working in that but not any new one other than that..
This is a feature of nokia 3315 by which if u set it on, then every time u insert new sim for first time then it will ask for the security code,, now as I have forgot that then i am forced to use my other sim in that...,
so if anyone is having solution then tell me, ie otherthan going to service professional..
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 18-11-2004, 11:10 PM   #2 (permalink)
IG
goto profeesional dude.its the safest and best way.
IG is offline
Old 18-11-2004, 11:39 PM   #3 (permalink)
call up ur servic provider
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 19-11-2004, 12:12 AM   #4 (permalink)
or try out the default security code.
guru is offline
Old 19-11-2004, 11:42 AM   #5 (permalink)
tuxfan's Avatar
By default the security code in all Nokia handsets is 12345. Try that. It should work if you haven't changed it. If you have and don't remember then you have a way out if you are in Mumbai. Go to Heera Panna shopping, look around a little, you will find someone who will reset the code for you for about Rs. 100. Or go to Nokia Service Centre.
tuxfan is offline
- by gohan89
