Originally Posted by suave_guy
I use Pixelview tv tuner and my o/s is winXp, but i haven't experienced any dropout of frame rates irrespective of the scene....
What is the resolution at which u guys watch tv....and also the graphics card??
Btw i play at 1024X768 resolution and have a geforce2 MX graphics card.
Also make sure that you have latest capture/tv tuner device drivers....
Enjoy!
I too play on1024x768 resolution, but do not have grafic card. I have v good configuration (P4, 2.8 Mhz, 256 RAM, Integrated grafic2 (shareed ram 64 MB), but only 14-16MB RAm is used when checked in used resorces, This leads to conclusion that no extra RAM ( graffic card too ??) required. Can u pl. dissable graffic card & check the problem. If u get the same problem, then I will make buy decision for graffic card.
