Old 05-06-2006, 06:27 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Torrent thing ! ! !
hi am new 2 torrents, just cant get it ... i have bittorrent tried searching bt nothing happens ...
whereas limewire pro works 4 me ... can anybody explain me abt torrents in short ???
say in few lines, how it works & how 2 use it ???
ax3 is offline
Old 05-06-2006, 08:06 PM   #2 (permalink)
puja399's Avatar
Default Re: Torrent thing ! ! !
Read these:
http://www.bittorrent.com/faq.html
http://www.dessent.net/btfaq/
http://btfaq.com/
http://www.afterdawn.com/guides/arch...orrent_faq.cfm
BTW, u may try torrent harvester (http://www.fixmypcsite.com/torrentharvester)
puja399 is offline
Old 06-06-2006, 12:23 AM   #3 (permalink)
speedyguy's Avatar
setup ur configuration as per ur connection....theres nuttin else to b done
cheers
No Pain...No Gain
speedyguy is offline
Old 06-06-2006, 12:29 AM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
guys i use azureus. I have a question. sometimes some files download real slow and after a long time (like 3-4 hrs) they speed up. Now what i want to know is that if for some reason i have to stop/pause that torrent and later when i resume it then will it take the same time to get back to speed or the usual time
what factors affect this resuming to full speed?
Rollercoaster is offline
Old 06-06-2006, 11:30 AM   #5 (permalink)
ax3
ax3's Avatar
thanx 4 the replies ... will check those links ...
ax3 is offline
Old 06-06-2006, 01:37 PM   #6 (permalink)
ax3
ax3's Avatar
is it necessary 2 install Torrent Searcher sa 1.0 also ???
am trying utorrent ...
ax3 is offline
Old 06-06-2006, 01:56 PM   #7 (permalink)
vignesh's Avatar
USe utorrent or Limewire
vignesh is offline
Old 06-06-2006, 02:27 PM   #8 (permalink)
saurabh.sauron's Avatar
chances r that the time left will increase, but not always. it depends on the file size, the torrent client and the percentage of download completed. if u pause it, i think first azureus checks how much percent has been downloaded.
saurabh.sauron is offline
Old 10-06-2006, 01:58 PM   #9 (permalink)
ax3
ax3's Avatar
which torrent site would u recommend me for downloading ebooks or pdf files ???
limewire, its not torrent 1 right ???
ax3 is offline
Old 10-06-2006, 02:15 PM   #10 (permalink)
mayhbp's Avatar
downloads spees depend on the seed and leecher concentration.
if the torrent is new u get good speeds.
well i get a avg of 30 in a 256 connection which is preety darn good!!
the client i would advise is µtorrent.it consumes the least cpu usage,unlike azureus which is rather heavy(but good if ur prof in dealing with torrents).
the next thing is configuring it according to ur net speed eg select network as 256x for a 256 kbps connection.the general global upload ration is 22 for 256 kbps.
the most important thing is the port forwarding.select a port(default is ok)
6881 is banned so none of the banned ones.
now test wether the port listed in µtorrent is forwarded.the option present there..
and yes u can get ebooks(torrents) at torrentspy.
if still u get low speeds then add the port(which ever u have selected) to the exceptions in the windows firewall(at ur own risk) but i do it.
HOpe this helps
mayhbp is offline
- by gohan89
