ull get onboard sound and graphics on amd boards as well
for onboard graphics look for boards with nforce2 chipset
apart from this the config u mentioned..
well first and formost the pentium 4 extreme edition will not support the 925 chipset ... or rather vice versa
the new pentium socket lga 775 ( 925/915 chipsets) will support the newer processors with the same socket
now lets calculate
the mobo when it hits ....
the top of the line would touch a 15k easy
the processor not sure ... maybe another 15k ?
ddr2 ram is not supported on the 925 chipset .. or rahter those boards wont be out for sometime now
so corsair 1gb ddr400 ram would cost u nuthin less than 12k
intel doesnt manufacture cabinets ....
so a normal cabinet + smps ... ard 1200-1500
cdrw = 1750-1850
dvdrw = 7500-13000
FDD = 300
logitech kbd+optical mouse wired = 1150
winxp ... = god knows ... 8k or soemthing ?
best linux distro = 1500
for that config 15" is tooo less
anyways ull get it for ard 5k
this crosses probably the 70k mark atleast ...
so u need to be sure abt ur hardware ... u cant go in for new hardware for a budget of 50k
for all the top of the line things ... i think u need a min. of 1lac ... 1.5 would be best ... and i mean MINIMUM. .. then too ur pc will be outdated technology wise within the year
anyways go in for what these guys suggested ... its the best u can afford ...
the creative sound card get the 5.1 value edition ...
i think thats what blade was talkin abt
and for the speakers ... well look into it ... go in for a 5.1 if u can .. z it would just be a waste otherwise ..
or for now u can settle for the onboard 6.1 channel audio and get the sound card some other time
