Double layer means there is data on both sides of the DVD i.e you flip the DVD over to use the other side.
Dual layer means there are 2 layers on the same side of the DVD.
How come Digit gave Dual layer dvd with 8gb software on this month at 200 Rs adding the cost of Magazines and Cd's and all ?
Where did they get those DVD's from? Does someone know ?
250 bucks is for writable DVD's. What Digit gives is pressed DVD's which barely cost anything.
If you put the Digit DVD in your drive and run Nero CD-DVD speed, it will be recognised as a DVD-ROM and not DVD-R.
