Old 04-06-2006, 06:47 PM   #1 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Unhappy Whare Is The Problem In PC!Plz Help
Whenever I am going to turn on my computer,there is only LED Of Hard disk
is continuesley lighting. n nothing is happning.
WHAT IS THE PROBLEM.
I am sure that is not prob of ram.
bcoz i alredy cheked this N also
my old ram is working fine on freinds computer.
Orionz is offline
Old 04-06-2006, 07:35 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: Whare Is The Problem In PC!Plz Help
most prob your master/slave config is bad or hdd cable not connected properly
Rollercoaster is offline
Old 04-06-2006, 07:48 PM   #3 (permalink)
You might also wan tto try this ..take out the power cord from the main unit & then press the start button.Then again plug the power cord again .
Alos directly plug your main unit[cabinet )(CPU ) to A/c instead of Using UPS ..
robin345 is offline
Old 04-06-2006, 07:54 PM   #4 (permalink)
^^^Explain Logic plz????
Old 04-06-2006, 11:40 PM   #5 (permalink)
MegaD3th3K's Avatar
just disconnect your hdd... now do you still see the LED Of Hard disk glowing? no!
ok just jokin. i had this prob once. i was able to run live linux using my dvd drive. so i guessed the prob was not with ram or ne thing like that. it finaly turned out to be the hdd's prob. i got it replaced. but same damn thing happened again. so obviously not hdd prob but still something had to be replaced right! Now my 4th hdd in 9 months. thankfully this is working properly (although i must add that i changed the RAM & PSU)
MegaD3th3K is offline
Old 05-06-2006, 02:47 AM   #6 (permalink)
samrulez's Avatar
Try fresh IDE/SATA and Moltex cables......Is it atleast going to the BIOS..if yes then "Load Default Settings"
Sam :D Rulez :lol:
samrulez is offline
Old 05-06-2006, 06:55 PM   #7 (permalink)
khansdream's Avatar
Post Re: Whare Is The Problem In PC!Plz Help
Check the connections of IDE and Power cables to HDD. You wouldn't get display until HDD is properly connected.
khansdream is offline
Old 06-06-2006, 11:22 AM   #8 (permalink)
thetopcyborg's Avatar
this happened to me also...i just unplugged the hard drive, cleaned its connectors(by blowing, of course) and even unplugged the cable of the hdd form the motherboard and reconnected.....it worked fine.....it has happened to me about 4-5 times and this method always works
thetopcyborg is offline
- by gohan89
