| Forum |
#1 (permalink) |
Please take little time to suggest me the following My current Pc config is P III 933Mhz Proc + MSI mobo 40 Gb Hdd 256Mb Ram.Now The basic work of Mine requires ripping & encoding Dvds to Vcds and sometimes divx but with the current config it takes hours to rip a single dvd.So now I am planning to buy a new sys so pls suggest me the best and fastest processor based pc PROC : should complete the work at earliest so should I buy Intel or Amd or any other or should I go for dual proc etc if it is feasable + compatible mobo,ram,etc etc .......... Also tell me weather it there can be any harm in using such new proc (with adequate fans for cooling) continiously for ripping and encoding dvds or any work which requires constant cpu usage for a larger time? Can I be rest assured that no damage will done to cpu by doing such heavy work continiously for 8-10 hrs / day or more ????????? if req What Implications will it have on cpu?? will its life get reduced or what..........????? I guess you all understood what I meant to say so its your turn now................ |
#3 (permalink) | |
DO U GUYS THINK THAT U SHOULD REPLY ??????? |
#4 (permalink) |
Yup he is right , but there is not a Hhhhuge difference between AMD and Intel in deconding considering the correcponding PR rating of an AMD chip , hardly a fraction of a second to a max of 10 secs diff , but imagine the scalability and other advantages of AMD64
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK |
| Bookmarks |
| Display Modes | |
