Old 04-06-2006, 03:34 PM   #1 (permalink)
Default which brdband to go for?
I wanna go in for a new broadband connection and want ur opinions...
the options which i currently hav are
MTNL
590NU
-------256kbps,1gb dwnload limit,night unlimited(from 12:00-8:00),total cost-around 920(including telephone rental of rs 250)
Airtel
699PLUS
128kbps,unlimited usage,total cost(784)
Sify
256kbps,1gb dwnload limit,total cost(566)
and
128kbps,unlimited dwnload,total cost(791)
the questions which i hav in mind are
1)Which of these interenet providers offer the best service and connectivity
.i've already got a mtnl connection and its service is allright
2)Is there a lotta difference in 128kbps and 256 kbps(in terms of browsing speed)??i knoe dwnlaodin speeds will certainly b slower in 128kbps but the unlimited opttion is quite tempting.
Somedays you\'re the dog,
somedays you\'re the hydrant.
kreigsmarine is offline
Old 04-06-2006, 04:09 PM   #2 (permalink)
mayanksharma's Avatar
Default Re: which brdband to go for?
Look man during browsing,the speed doesn't matter at all.You will be fine in 128 and as well as 256Kbps.But yeah,downloading matters alot.Just imagine how files get downloaded to your system,with the speed of 32KBps!!
As far as service is concerned,you will be quite happy with Airtel.Connectivity is better.Go for sify,if you want consistency in speed and downloading.But i would rather recommend you to stick with Airtel.
Choose 256Kbps package with unlimited download facility,if you want to download hell lot of games and movies to your system,with superb downloading speed.
mayanksharma is offline
Old 04-06-2006, 05:06 PM   #3 (permalink)
well as my former person explains .......
this choice u should do depends upon what u want to do ? if u want to do massive
downloads then go for unlimited download . if u want to do some vedio-voice chat then 256kbps is reqd . anyway do whatever you can but NEVER CHOOSE IQARA .
hellomotto is offline
Old 04-06-2006, 05:13 PM   #4 (permalink)
well...i cant take the 256(unlimited) option cuz thatz byond my budget.
well,yes,i do plan to dwnload stuff(songs and videos mostly).i think 128 wud suit me cuz it doesn matter a lot whether stuff gets dwnlaoded in 1 hr or 2hrs.
My main query is only bout the service quality.I mean sumtimes it happens that the mtnl connection i've got jus stops workin in between.i then hav to restart the router or restart my comp...and all that sorta crap.
Old 04-06-2006, 05:39 PM   #5 (permalink)
wellbest idea is frist take a small budget plan....like say 512 Mb per month , use it one month and see hows the service and how much u need it ...then accordingly shift to some other plan .
Old 04-06-2006, 05:45 PM   #6 (permalink)
Official Techie's Avatar
well go for dsl 590 NU it works very smooth i currently have it and till today i didnt encounter any serios sproblem
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 04-06-2006, 05:47 PM   #7 (permalink)
nach p's Avatar
I am using Sify 128kbps unlimited downloading offer for more than 6months and as a qualitywise Sify is best as constant download ,never automatic disconnection or server down problem.I am getting 15-16 kbps downloading speed whereas 12-13 uploading speed .Sify gives 64 kbps line for uploading in this 128 unlimited plan which is b*******.So you can go for Sify.
I have no experience abt Mtnl ot Airtel.
nach p is offline
Old 04-06-2006, 05:54 PM   #8 (permalink)
sify is good my friend but speed doesnt matter for surfing it matters when u download for example last night i started downloadind tms sunrise demo and calculated the time at 240 kbps needed for download and put on the alarm when i woke i saw that the download had already finished sow 256 Kbps mtnl night unlimited plan is very good
Old 04-06-2006, 08:00 PM   #9 (permalink)
ashfame's Avatar
donot go for any of these!!
there is a plan for airtel @ rs. 699 which offers 128kbps in day & 256kbps in night (unlimited).
Go for this one.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 04-06-2006, 08:20 PM   #10 (permalink)
@ashfame:
We are mentioning about that very same plan dude!! i.e. Airtel 699Plus with 128Kbps speed.
Old 04-06-2006, 08:36 PM   #11 (permalink)
ashfame's Avatar
Originally Posted by mayanksharma
@ashfame:
i can't see where??
ashfame is offline
Old 04-06-2006, 11:34 PM   #12 (permalink)
@ashfame--i've been checkin the net for the airtel 699plus plan,but nowhere hav i found it sayin that u get 256 at night.cud u pls elaborate on this?wat time in the night does this 256 thing start and wat time does it end??
Old 05-06-2006, 12:21 AM   #13 (permalink)
dIgItaL_BrAt's Avatar
u get double the speed (256 kbps) from 10:30 pm to 6:30 am.
dIgItaL_BrAt is offline
Old 05-06-2006, 01:05 AM   #14 (permalink)
dOm1naTOr's Avatar
try using softwares like bandwidth monitor to monitor the speed change. start a big download and wait watching the graph until the bandwidth increases.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 05-06-2006, 05:40 AM   #15 (permalink)
nishant_nms's Avatar
U can even get 256 Kbps unlimited downloads with Sify for 1000 Rs.
I would suggest you to go for sify because as per my experience it is the best provider and u will get constant speeds at the promised rates.
nishant_nms is offline
Old 05-06-2006, 07:55 AM   #16 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Sify has a LOT of downtime.. I had sify before.. Sify plain sucks, they dont care for the customer. Go for airtel 128kbps unltd. The best plan right now for you IMHO.
@ashfame: look at the first post dude!
kalpik is online now
Old 05-06-2006, 03:58 PM   #17 (permalink)
nach p's Avatar
I never faced any problem on Sify .Downtime not at all.If you faced such prob. then it may be u r local area connection prob. or u r provider doesnt care customers.
I used pacenet before facing downtime problems but same isp gives excellent service in another area!!!!
So it may depends on local service providers who manages all da service.Also plans may differs areawise.So it is better to collect info abt internet sevice provider in our local area on our own.
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 05-06-2006, 04:38 PM   #18 (permalink)
mohit sharma's Avatar
Originally Posted by kreigsmarine
Airtel699PLUS128kbps,unlimited usage,total cost(784)
this total cost comes with ::
1 :: rent free telephone connection ( i mean u had to just pay for calls u made ) .
2 :: double speeds at nights [ 256 kbps ] .
3 :: the most precious thing quality service at any time for any fault .
so my suggestion will b to go 4 airtel .
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
mohit sharma is offline
Old 05-06-2006, 04:44 PM   #19 (permalink)
vignesh's Avatar
Go in for Airtel.... The best broadband service I have seen... Get their new 250/- plan
vignesh is offline
Old 06-06-2006, 04:27 PM   #20 (permalink)
Sify.............simply superb toll free help line lots of support and it really works superb just 500/-Rs/ per month 128 kbps unlimited i m using..........
its really really good service...........
dikudik is offline
Old 06-06-2006, 06:05 PM   #21 (permalink)
prasad_den's Avatar
If you are willing to spend around 800 bucks, then you can very well spend 900 for the BSNL Dataone UL900 plan, which offers 256kbps speed with unlimited downloads... Real cool plan with good speeds...
prasad_den is offline
Old 06-06-2006, 06:09 PM   #22 (permalink)
Commander in Chief
QwertyManiac's Avatar
Airtel from those options u got. Dont look at anything else for now, until MTNL introduces UL at low prices...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-06-2006, 08:11 PM   #23 (permalink)
R u Guys Crazy Sifys D most F***up ISP There Customer service Is So Cool Dat They Donot Even answer the phone calls This Is What My Experiance wth Sify In New Bombay
yogesh1990 is offline
Old 06-06-2006, 09:48 PM   #24 (permalink)
@prasad--the mtnl unlimited plan comes for a cool 1300 bucks per month....which is way outta my budget...
Old 07-06-2006, 12:30 PM   #25 (permalink)
GO FOR BSNL HOME 500 PLAN
FEATURES....
1...monthly rent of rs 500
2...speed max 256 kbps
3...max download limit 1 GB
4...night time free
5...if u exceed download limit..rs 1.2 per MB of extra download
6...faster than most other private 'broadband' providers
hellboy_extreme is offline
Old 01-07-2006, 07:03 PM   #26 (permalink)
Ishan's Avatar
@hellboy_extreme
u r telling that Bsnl is night time free...but actually its not....Try to calculate the Total Kb column and the last column where they write "0" for night time use...And see the difference...Man u'll surely get shocked..
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 01-07-2006, 08:47 PM   #27 (permalink)
JGuru's Avatar
Go for Airtel. It's the best one as far as broadband is concerned.
JGuru is offline
Old 01-07-2006, 09:19 PM   #28 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Well i'l recommend Airtel , i've got a 512 kbps UL plan and i get dwnload speeds of more than 60KB/s all the time .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
- by gohan89
