Old 17-11-2004, 07:13 PM   #1 (permalink)
Default double trouble with yahoo messenger?
hi digitizers
did any 1 try the patch mention in nov digit article on configuring yahoo messenger to run for two acounts simulatneously.
i tried downloading that file and when i opened it i get error and hence it does not work.
plz do help as i hav 2 yahoo acounts and i use both of them.
snehal_prabhu is offline
Old 17-11-2004, 10:18 PM   #2 (permalink)
helpppppppppppppppppppppppppp
Old 18-11-2004, 01:19 AM   #3 (permalink)
hi dude!
Well b a little cool man.
Listen 1 thing... b4 u get into to post try out the search in digit. U got to get ur answer.
Neways---->Go to Google----> Search Yahoo Multi Gold-----> Download n install it
I don't know y the patch by digit failed to sprout but u gotta get a deal with this.
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 18-11-2004, 09:05 PM   #4 (permalink)
busyanuj's Avatar
Default Re: double trouble with yahoo messenger?
Originally Posted by snehal_prabhu
hi digitizers
go to GAIM website and download GAIM messenger.
Then you can simultaneously login into as many Yahoo, MSN etc. accounts as you want.
busyanuj is offline
Old 18-11-2004, 09:29 PM   #5 (permalink)
ok buddy if you want I knw how to do it I will do that but only after my exams. I f you know how to patch I can give you instructions.
killerguy is offline
- by gohan89
