Old 17-11-2004, 05:31 PM   #1 (permalink)
nipun_the_gr8
Posts: n/a
Default Help me plz.........
Plz hlp me as i am unable to delete the "microsoft frontpage" & "xerox" folders dat have been created in C:\Program Files folder...........
When i try to delete those folders,an error msg appears:
Afer usin' "Who Lock Me", it tells dat the folders have been locked by WINLOGON.EXE
Plz tell me dat shud i kill the process & delete those folders or not....
Old 17-11-2004, 06:26 PM   #2 (permalink)
GameAddict's Avatar
Default Here is the "desi" way...
Hi,
Soon the guys will come with better solutions...but here is the desi(quick and dirty) way of doing it.
Boot from DOS Bootable, navigate and delete the troublesome files
Bye!
GA
GameAddict is offline
Old 17-11-2004, 06:36 PM   #3 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Here is the "desi" way...
I'll tell you an even dirtier solution:
Boot from Knoppix Live CD ... mount that partition... and remove the files and folders that you dont wanna have...
http://web.gnuer.org
GNUrag is offline
Old 17-11-2004, 09:22 PM   #4 (permalink)
I ld prefer booting from a win9x startupdisk.
amitsaudy is offline
Old 18-11-2004, 12:03 AM   #5 (permalink)
rajat22's Avatar
Tried in safe mode?
rajat22 is offline
Old 18-11-2004, 12:37 AM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Offoh ... DONT DELETE those folders ... The Frontpage folder is required by Frontpage extensions...
It isnt harming your hard disk .. let them be at peace ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 18-11-2004, 01:55 AM   #7 (permalink)
yes let those folders b there. unless u got a kick of getting ur comp looked clean
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 22-11-2004, 05:06 PM   #8 (permalink)
nipun_the_gr8
Posts: n/a
Ok.........
Thankx.........
Old 25-11-2004, 12:35 PM   #9 (permalink)
it can be solve from many ways
1. start pc with safe mode and delet
2. u understand pure dos(bootable disket)and shift over drive and delet
sheladiya chetan
chetan is offline
- by gohan89
