Old 01-06-2006, 04:22 PM   #1 (permalink)
Default ~DVD Splitters~~
well...guys i have been trying to find a software which could split a vob file.....~~~by splitting i mean just splitting n not ripping it into some .avi format and then splitting...that's no big deal ...i got a Super DVD Ripper ...but the problem is that it took around 1.5 hrs to 2 hrs just to rip one .vob file of some .99gb size...that's hell lot of time..
i even got this Allok Video Splitter...but the problem is to select which codec for splitting..otherwise it doesn't work...
could anyone plz recommend a software which could just split a .vob
file and preserve it in smaller .vob files...
tech_freak is offline
Old 01-06-2006, 05:41 PM   #2 (permalink)
ashfame's Avatar
Default Re: ~DVD Splitters~~
wrong section dude!
i never participate in a thread in the wrong section but this time i didn't realize its in the tutorial section.
take care from next time
ripping is a processor intensive task & u might hav noticed that whenu rip ur cpu usage in taskbar jumps to all time high!
its that only. maybe u hav a slower processor.
it requires lot of calculations that cpu has to done & if ur cpu is not a >3ghz monster, it will surely take time.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 02-06-2006, 10:10 AM   #3 (permalink)
Smile Re: ~DVD Splitters~~
well...sorry for posting it in the wrong section...
but my problem wasn't that...even i have 3Ghz processor...what i was asking was for a software that could split a dvd without ripping it...if u could just tell the software name...that would be good..
Old 02-06-2006, 10:18 AM   #4 (permalink)
Thumbs up Re: ~DVD Splitters~~
there is a software
DVDCutter Stream and Mp3CDWav Converter
http://www.soft32.com/download_14710.html
http://www.freedownloadscenter.com/M...Converter.html
it does cutting job and more too....
trial version....
checkit out and post the results
thanx
Sharing Knowledge Expands Horizon... And Problems r solved
bikram_singhy is offline
Old 09-06-2006, 07:33 PM   #5 (permalink)
Are we there yet?
amrit1's Avatar
what hapend to this forum???? everybody is posting in wrong section
are admins and mods are sleeping
amrit1 is offline
- by gohan89
