There is nothing like maximum & minimum processes.It depends upon the type of services you need.
Say for example you use a device that supports infrared,for that purpose you need to have the "Infrared Monitor" service running.Same may not be the case with someone else.
Just post the screenshot of taskmanager with the Processes tab.
Visit blackviper.com for a detailed description of each service.
www.Oobertech.net
