Old 01-06-2006, 09:37 AM   #1 (permalink)
Default Demon tool message...is it of concern ?
hi
i have 700 mb iso file.......after reading lot on google about iso i decided to install daemon tool.....while installation i got this massage......
http://img344.imageshack.us/img344/4798/d3st.jpg
This programm will install scsi pass through direct SPTD layer on my computer warning....SPTD is not compatible with kernal debuggers softICE.winDBG etc
please cancel setup if you plans to use kernel debuggers on this machine...
tell me is it of concern or its regular alert while installing D tools....
what should i do now....should i proceed....?
mkmkmk is offline
Old 01-06-2006, 09:52 AM   #2 (permalink)
rajesh's Avatar
Default Re: Demon tool message...is it of concern ?
I dont know about the prolem, but for getting the contents of the ISO, WinRAR is enough.
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 01-06-2006, 10:29 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Originally Posted by mkmkmk
hi
Yes, thats normal. Just press OK, then it will ask you to restart and thn setup will continue.
kalpik is offline
Old 01-06-2006, 11:07 AM   #4 (permalink)
Thanks. for reply now i will use isobuster.about winrar i dont know ,no one suggested me ...lets i will try that ..thanks for this tooo
mkmkmk is offline
Old 01-06-2006, 11:31 AM   #5 (permalink)
following steps...when i m using iso......i m not getting what to do now.....
this is original iso image......
http://img20.imageshack.us/img20/3269/iso20wd.jpg
with damon tools..
http://img20.imageshack.us/img20/9963/iso37kd.jpg
http://img20.imageshack.us/img20/9397/iso50hm.jpg
i m not getting next step..so pls guide me....
should i extract ...like this...
http://img234.imageshack.us/img234/3...extract7as.jpg
tell me next step......
mkmkmk is offline
Old 01-06-2006, 12:05 PM   #6 (permalink)
Back From Deathstar
Darthvader's Avatar
Right Click on shortcut button of daemon tools beside the time on taskbar.
Then go to virtual cd/dvd roms> device 0> mount> browse to the image>open> voila u r done
Then the cd shud autorun or u could just g to the drive or browse urself.
Darthvader is offline
Old 01-06-2006, 03:33 PM   #7 (permalink)
thankssssssss Darthvader...........it worked me like magic......
mkmkmk is offline
