Old 31-05-2006, 03:31 PM   #1 (permalink)
sagar_coolx's Avatar
Default How many svchost.exe?
hey guyz, i have winxp sp2 on amd 64 3200+,1 gb ddr400 ram,asus a8ne ,gforrce 6600 gfx.
whenever i see the processes in task manager, i find that there are many processes by the name svchost.exe,and they are using a lot of my memmory. can it be a spyware?but spybot and adaware do not show anything.what can it be due to?
sagar_coolx is offline
Old 31-05-2006, 04:18 PM   #2 (permalink)
MVP in VC++
Default Re: How many svchost.exe?
No it is not a spyware.
But , Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs).
For more details check the following link.
http://support.microsoft.com/?kbid=314056
cvvikram is offline
Old 31-05-2006, 05:43 PM   #3 (permalink)
i agree, but then there should just 1 process. why so many??
Old 31-05-2006, 06:27 PM   #4 (permalink)
parthbarot's Avatar
i also doent dig into OS fundas... but u can dload some 3rd party software like processExplorer from www.sysinternals.com
and it will show u all processes running with the path of that exe file...so u can easily track which is fraud and which is OS svchost
as i have used it and caught many files as spywares which are running under names of OS files..
so try softs like this..
Regards.
www.techlads.com
Paarth.
parthbarot is offline
Old 31-05-2006, 06:28 PM   #5 (permalink)
ionicsachin's Avatar
Each process is for different use. Like one is for the windows shell, other is for backward running applications and some are for power management.
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 31-05-2006, 06:53 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
...but svchost.dll is a Trojan Backdoor.Shellbot .....................
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 31-05-2006, 10:32 PM   #7 (permalink)
I think that's related to your modem. Not so sure bout this though.
thecyclone2k is offline
Old 01-06-2006, 12:59 PM   #8 (permalink)
actually svchost.exe runs multiple copies for different purposes!
it takes different forms by using command line arguments!
it does all kinds of stuff!
run> services.msc and chk out properties of services running N u'l know which services need svchost!
if u dont want any stop them.however this can be risky
Earth is full.Go home.
adorablesrini is offline
