Old 30-05-2006, 09:52 PM   #1 (permalink)
ionicsachin's Avatar
Smile Reduction of size....
Hi,
I ve got a gif animation which i want to put as my "avatar". But the problem is that its size is greater than 300 KB and Digit Forum allows only 15 KB. Is there any method to reduce its size.
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 30-05-2006, 10:52 PM   #2 (permalink)
santu_29's Avatar
Default Re: Reduction of size....
no need to import it to flash, you can easily resize it here: http://www.gifworks.com/image_editor.html
Unless you have a dream, you are not going to achieve anything in life.
Shoot for the moon, even if you miss, youll fall in the stars.
******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ******************
santu_29 is offline
Old 31-05-2006, 11:43 AM   #3 (permalink)
the deconstructionist's Avatar
The best is use irfan view the software is on old cd of digit. Then load your pic and resize to your requirments.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
