hi guys
i m facing a new prob. now a days. i recently installed vista transformation pack 4.0 which was either not compatible with my pc. so i uninstalled it. then onwards 1 prob has arised. my taskbar has changed 2 windows classic style & in appearance bar it is not showing any other option 222222. what should i do 2 regain it. plz tell me faaaaaaast
hi BHAILOG
apun ka subko salaaam-namaste
Go to System properties->Advanced->Performance->Settings-Visual effects, now you will have three options here choose either the first one or the third one.
Then apply the and then OK.
Reboot.
Hope your problem will get solved by this.
i have u eanabled the theme service??
if not enable its services app through control panel>performance & maintance>adinstrative tools>seach for a services shortcut.
i can't tell it clearly beacuse i am not a windows greek in using linux i swicthed recently
