How 2 convert avseq.dat files to mpeg/rm/avi???
guys, i have many vcds, in which all files are in avseq.dat format, which take up considerable anount of space when copied to harddisk, so is there any software which can convert the avseq.dat files to mpe or rm or avi?
Digitizor - How-To Guides, Tips and Tricks, Latest from the tech world and much more... visit http://digitizor.com/ now
Re: How 2 convert avseq.dat files to mpeg/rm/avi???
you can use virtual dub ( a free open source utility) to encode mpeg files to divx or other mpeg4 compression provided the proper codec installed. For divx install DivX Create Bundle or for XVid install XVid codec. THese are standard mpeg4 codecs and can be playable in most DVD/DivX players. You can easily convert a 2 CD movie to around 500MB with minimum loss of quailty.
__________________ Quitters Never Win & Winners Never Quit!
If you want to convert use VCD gear..(google for the link )
if you want to encode use virtual dub or imTooDVD ripper for .vob with proper codes installed.
Best code is XviD or VP7 ..
You and Me forever be ...
PSpwned
try blazemp its great...
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
