Old 16-11-2004, 01:49 AM   #1 (permalink)
doom_marine's Avatar
Default DOOM 3 Problems
I just bought a laptop with a Radeon 9600 Graphics card. All my games ran fine on it but DOOM 3.
The thing is that the demo that digit gave ran fine for some time time my display got fully corrupted. I bought the full version and installed it, it ran fine for some time but when it crashed it crashed onto the desktop.
When the demo crashed i could not do anything but reset my laptop.
Please help i have all the latest drivers installed
doom_marine is offline
Old 16-11-2004, 05:09 AM   #2 (permalink)
hmmm...can u give ur config??? i mean apart from processor, RAM, etc., give the amount of memory ur card has....
Nemesis is offline
Old 16-11-2004, 06:27 AM   #3 (permalink)
The Photoshop Guy
cooljeba's Avatar
and the OS dat you use.... mostly it will be XP anyways can u give us more detail doom_marine
..:: peace ::..
Jeba
cooljeba is offline
Old 16-11-2004, 07:25 PM   #4 (permalink)
Mobile Proccessor With Centrino at 1.6GHz 64MB ATi Radeon 64MB 512MB RAM 60GB RAM
Can Someone help Me
Old 16-11-2004, 07:48 PM   #5 (permalink)
Does this problem occur with other graphics intensive games? There might be a possibility that the graphics processor is getting overheated. See that you are not blocking any openings for air. Also try updating the drivers if you have not.
game_dev is offline
Old 17-11-2004, 07:14 AM   #6 (permalink)
well its probable that ur computer does not enough resources left 2 play the game...i mean try disabling ur antivirus and shutting down all useless applications...if u can access the menu of the game, then try setting all the graphics settings 2 the lowest settings....
Nemesis is offline
Old 17-11-2004, 08:39 AM   #7 (permalink)
Yeah Other games run fine and no blockage of air.
the graphics are on lowest setting
