hi guys
somedays ago i was tryin 2 write an iso image 3.7 gb on a dvd. i successfully writted it but my pc is not recognizing it. it not even shows what it contains & tells it 2 be free space.what should i do now.plz tell me the way of writing images.
hi BHAILOG
apun ka subko salaaam-namaste
Either you wrote it only in simulation mode and didint actually write it. Or the DVD media you are using is currupted.
To write , any Software is good though Nero is generally Easy of the lot in terms of interferace.
Try changing the media and see. Also be sure whatever you are writting on the DVD is not itself currupted file bacause you will only be wasting the Precious DVD Media's.
