Old 15-11-2004, 08:19 PM   #1 (permalink)
Default networking with blue tooth......
i want some good lessons so that i can play multiplayer game on two networked computers and if possible share internet.
thanks
sscheema is offline
Old 15-11-2004, 08:25 PM   #2 (permalink)
vysakh's Avatar
welcome to digit forums...
well if ur computers are networked, it is easy
in the game take multiplayer and select the option network. if that is not there try LAN
Incompatible message format
vysakh is offline
Old 15-11-2004, 09:28 PM   #3 (permalink)
u nan connect two PC by making LAN, in that case u have to use network card and using that u can connect directly using a crosslinked cable, and also u can connect using parallel cable, for that please read 30 minutes expert in Digit , i think August or July ...
Knowledge is power!
curvenger is offline
