Dude.. Music Match JukeBox is a Shareware and this trial version, i dont think it allows line-in recording.. SOundForge is good, thou i personally recommend harddiskogg.. Thats wat i recommend to my customers..
Its simple, efficeint and easy to use..
You can download it from here.. (U also need to download a Lame MP3 DLL from the link mentioned on the site)
http://www.fridgesoft.de/harddiskogg.php
If u need the seetings on your computer like setting line-in etc so as to obtain max performance with the manual for using it mail me..
