Old 15-11-2004, 03:15 PM   #1 (permalink)
vysakh's Avatar
Default RAM
recently i read somewhere that we should not use second hand RAM. is it true???
Incompatible message format
vysakh is offline
Old 15-11-2004, 03:56 PM   #2 (permalink)
yes...unless u know the dealer extremely well usage of second hand RAMS is not at all advisable as you can be cheated easily.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 15-11-2004, 04:42 PM   #3 (permalink)
Well using second hand ram is no problem if the module is what u want.
The risk is when you are buying it cos its very easy to be conned.
amitsaudy is offline
Old 15-11-2004, 04:55 PM   #4 (permalink)
get the ram run memtest an it for 12 hrs if pass it is as good as new
**** happens
pradeep_chauhan is offline
Old 17-11-2004, 11:22 AM   #5 (permalink)
You can get memtest here: http://www.memtest86.com/
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 17-11-2004, 01:59 PM   #6 (permalink)
Default well
well isnt it the thing that either it works or not
i think its all the rumor out of some hardware house
well are there any snags using second hand things
well it is abvoius that 2nd hand things may not assemble well or maynot be durable
well may be
thks
saha
be who u r :
Saharika is offline
Old 18-11-2004, 01:32 AM   #7 (permalink)
noprobs with 2nd hand RAM.
When it comes to old pc's with SDRAM compatibility which has vanished from the markets... u need that pinch!
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 18-11-2004, 01:40 AM   #8 (permalink)
No one should be that confident 'bout a second hand electronic product! Trust me!
indrajit is offline
Old 18-11-2004, 01:51 AM   #9 (permalink)
i know but wats the use of a gun with no bullets?
Withouth RAM u don't have the space to breathe too!
Just a little care in buying n u get all wat u need.
Old 18-11-2004, 02:01 AM   #10 (permalink)
Yes. But then you'll have to totally depend on your luck. There's no way of doing a quick test on a RAM module while buying it (at least I don't know of any). The memtest link given above takes about 30hrs approximately to complete checking a 256MB module.
indrajit is offline
