Old 25-05-2006, 10:58 PM   #1 (permalink)
jamyang312's Avatar
Exclamation unable to delete temp files!! suspect- worm!!
i have some .tmp files like JET4ADD.tmp,JET5C00.tmp,JET410C.tmp and some dat files like Perflib_Perfdata_4f4.dat and many more and their size is 0 kb and also my connection is becoming slower!! my avast webshield also reported something like lsass exploit!!
what is happening? i suspect i have been infected with sasser worm!!
what should i do? please help!
note:i tried to delete with avast but it is unable to do so!!
think u will never see the devil?
look in the mirror and u will see one!
jamyang312 is offline
Old 26-05-2006, 07:36 AM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Re: unable to delete temp files!! suspect- worm!!
If anything doesn't work go to the command prompt( make sure u have closed WINDOWS) and try and delete them... this will work
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 26-05-2006, 08:32 AM   #3 (permalink)
ramprasad's Avatar
As vandit said, delete the files from command prompt and restart...If the problem still persistes, try to get an exclusive tool from Norton at http:\\securityresponse.symantec.com
ramprasad is offline
Old 26-05-2006, 11:39 AM   #4 (permalink)
Distinguished Member
anandk's Avatar
2 b sure pls post ur hijackthis logfile here or at www.hijakthis.de for analysis.
check my psot here on pg 2
lsass.exe ERROR
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-05-2006, 10:12 PM   #5 (permalink)
jamyang312's Avatar
how do i delete at command prompt? please clarify.
Old 26-05-2006, 11:28 PM   #6 (permalink)
vandit's Avatar
restart ur pc..... when it just starts... repeatedly press f8 then select command prompt..
go to the temp directory and del them..
vandit is offline
Old 27-05-2006, 12:03 AM   #7 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Use Unlocker to detect which programs are using those temp files... try unlocking and delete...
ShekharPalash is offline
Old 27-05-2006, 12:58 AM   #8 (permalink)
the deconstructionist's Avatar
Use startup buddy to know which file is infected. Next safe start the system using F8 and delete the file.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
