Old 24-05-2006, 11:15 AM   #1 (permalink)
santu_29's Avatar
Default IDE or SATA
i need to get a 40gb hdd, i am confused between 7200rpm sata or ide, the cost is almost the same, in case of sata ill haveto get a sata card also as my motherboard intel845gv does not have inbuilt sata support. how much will the card cost? please tell me whats better and why.... thanks
Unless you have a dream, you are not going to achieve anything in life.
Shoot for the moon, even if you miss, youll fall in the stars.
******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ******************
santu_29 is offline
Old 24-05-2006, 12:06 PM   #2 (permalink)
sms_solver's Avatar
Default Re: IDE or SATA
For your motherboard, it is better to go for IDE.
I would suggest you to go for SATA only if you are buying the new system and the motherboard has SATA support.
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 24-05-2006, 02:19 PM   #3 (permalink)
SATA..& also i will rather suggesy you to upgrade your Motherboard .
robin345 is offline
Old 24-05-2006, 03:39 PM   #4 (permalink)
Go for IDE. It will give you better performance with your motherboard. Or else look for fast 10,000 rpm + drives from westren digital or so. They will give on par performance with SATA. They r costly.
vinayasurya is offline
Old 24-05-2006, 06:45 PM   #5 (permalink)
aryayush's Avatar
SATA is obviously better if you have the dough.
If you can, and are willing to, upgrade your motherboard (as you rightly should), SATA is the way to go.
aryayush is offline
Old 24-05-2006, 07:20 PM   #6 (permalink)
santu_29's Avatar
well i cant upgrade my mobo as ill have to upgrade my cpu also in that case, its p4 2.4ghz.. so..
santu_29 is offline
Old 24-05-2006, 08:06 PM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Go for IDE.. There is not *much* performance gain with SATA.
kalpik is offline
Old 24-05-2006, 10:29 PM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
as in your case ide is the only option else SATA is the choice
gary4gar is offline
Old 25-05-2006, 12:59 PM   #9 (permalink)
the deconstructionist's Avatar
If speed is not your concern go for IDE. For people buying brand new system they should go for SATA.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 25-05-2006, 02:34 PM   #10 (permalink)
as for sata on the interface speed is 150 mbps where as ide it is 133 mbps,as we can see there is not much difference.sata drivers are not native to windows so u need to put floppy for sata driver during installation of xp if u plan to buy a sata hard disk and a card. which mean ur computer is dependend on the very unreliable floppy..
maximus is offline
Old 25-05-2006, 03:26 PM   #11 (permalink)
cooldip10's Avatar
Hey i have same mobo and am in pit with its incompatibility with everything.. I suggest you to get IDE HDD if and only if its urgent.. If not then wait for one yr as i'm doin', then get a new mobo which will be supporting VISTA. You can't waste money for buying a new mobo for one yr. satisfaction only... can u?
Everything is Possible
cooldip10 is offline
Old 25-05-2006, 06:55 PM   #12 (permalink)
kalpik's Avatar
Also the 150 MBps and 133 MBps speeds are just thoretical. Average speeds are generally in the range of 50-60 MBps for both IDE and SATA drives.
kalpik is offline
Old 25-05-2006, 07:05 PM   #13 (permalink)
santu_29's Avatar
i think ill go for ide, my present segate hdd has given me enough headache, ill get a 'western digital' hdd this time.....
santu_29 is offline
Old 25-05-2006, 11:30 PM   #14 (permalink)
True, For eg. my Hitachi SATA has an actual speed of 60 MBps only. It can be changed to SATA II with theoretical 300 MBps using "Hitachi Feature Tool" software, but I have not tried it since I dont think it will make any noticeable difference. Anyway I am going to experiment.
V.Prem Kumar
janitha is offline
Old 25-05-2006, 11:43 PM   #15 (permalink)
I just added a SATA 250gb segate to my 845glad mobo.
I had to buy a SATA to IDE convertor card for Rs 500/- single HDD, the same is also available for Rs 1200/- & supports 2 sata to IDE disk.
Running photoshop before on PATA & now on SATA does not make me feel any speed difference. I bought SATA just to be able to use it better whenever I change my comp.
Speed difference is negligible but so was the price difference so I better have latest technology.
ranjan2001 is offline
Old 26-05-2006, 07:29 AM   #16 (permalink)
kalpik's Avatar
If you have bought a SATA to PATA card, then obviously the drive will not work faster than PATA cuz the bandwidth of the IDE channel is the bottleneck.
kalpik is offline
Old 26-05-2006, 10:32 AM   #17 (permalink)
cooldip10's Avatar
That's true.. the sped will be according to IDE only after installing the card also..
Old 26-05-2006, 11:13 AM   #18 (permalink)
GaurishSharma.com
gary4gar's Avatar
in win sp2 which has native support for sata drive there no need of floopy
gary4gar is offline
