whenever i click on any *.reg files, it opens in notepad.
How can i chnage its association withthe registry so that value is added to the registry?
thanks in advance/.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
Goto: Tools -> Folder Options and in File Types tab look for REG extension.
After selecting REG extension, click on Advanced button and select Merge in the Actions section. Then click on Set Default button.
No use, it is set to open in notepad with every action.
