Old 14-11-2004, 10:40 PM   #1 (permalink)
Default Bluetooth driver
I lost my bluetooth driver C.D. how do i install it now
HELP
shriekers is offline
Old 15-11-2004, 02:25 PM   #2 (permalink)
too simple, search for the drivers on the net (eg. driverguide.com)
^ I wrote this!
akshayc is offline
Old 15-11-2004, 02:31 PM   #3 (permalink)
vysakh's Avatar
too big avatar
Incompatible message format
vysakh is offline
Old 15-11-2004, 05:42 PM   #4 (permalink)
Certified Nutz
sreevirus's Avatar
if u r using windows xp with service pack 2 installed, u dont need additional bluetooth drivers coz bluetooth is natively supported in sp2.
but can u let us know what make ur bluetooth device is(ie WIDCOMM, TDKsystems) and also its model number(if any)?
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 16-11-2004, 01:38 AM   #5 (permalink)
It's a WIDCOMM Device but the device does not have any name or model number written on it. My software C.D. Had Widcomm Software on it
Old 16-11-2004, 12:32 PM   #6 (permalink)
Bewitched!
xenkatesh's Avatar
akshayc
change or resize ur avatar is tooo big it should be only 90*90 pixels!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 16-11-2004, 02:19 PM   #7 (permalink)
well xenkatesh urs is 103*95
so i suggest u resize urs before tellin others
@shriekers and @akshayc ... widcomm does not give out drivers to end users. therefore finding them at something like driversguide.com MAY not work
so ur best bet is to download it from a company site like IBM
unfortunately u will not be able to use these without "patching" them fpr ur NON *company* (*IBM*) product
BUT FEAR NOT !!!
read the following and have fun
heres is where u can download the driers for IBM
http://support.fujitsu-siemens.de/KnowHow/Accessories/Start_GB_Accessories.htm?uri=/DriverCD/Accessories/_DriverSteuerung/GB/Accessories_Bluetooth.htm&menu=/DriverCD/../KnowHow/Accessories/_1st_Start/GB/MenuListe_Accessories.htm
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/bthwxp1o.exe
http://www-900.ibm.com/cn/support/download/attachment/JWAG-5LWBJS/bthwxp1o.exe
http://mirrors.phorever.com/jonscaife/bthwxp1o.zip
http://jonscaife.servebeer.com/public/Downloads/bthwxp1o.exe
now lemme make it tough to easy for u ... it might just be fun
if u love to mess ard and use hex editors do this
find
3B F5 75 0E 3B FD 75 0A
and replace it with
3B F5 90 90 3B FD 90 90
find
83 C4 04 85 F6 0F 85 1F 01 00 00
and replace it with
83 C4 04 85 F6 90 90 90 90 90 90
SOURCE : http://www.jonsguides.com/ but it no longer exists as its been removed due to broadcom
or u can download the patch from
http://www.jonsguides.com/bt/btpatch.exe
or smpler enuff u can download the patched files from
http://jonscaife.servebeer.com/public/Downloads/btfiles.exe
http://www.jonscaife.com/creation/btfiles.exe
http://mirrors.phorever.com/jonscaife/btfiles.zip
http://www.jonscaife.com/create/btfiles.exe
im sorry i didnt have the time to check the links for u ... but i think the quantity ive given should suffice
enjoy!
oooo and sreevirus is right ... u CAN use the drivers from SP2
but these widcomm drivers are said to be better ... even tho they dont have their WHQL certification .. thats the only problem
No Mercy, No Limits.
theraven is offline
Old 17-11-2004, 03:17 AM   #8 (permalink)
Certified Nutz
sreevirus's Avatar
well, if u r willing to experiment, u can try the bluetooth stack drivers form TDK....
http://www.tdksystems.com/download/b...toothstack.zip
i too have a widcomm dongle and got a mini cd with it...i havent tried the tdk software yet, but will sometime...and if u r going to install it, be sure to create a system restore point in case something gets screwed up.
@raven..man none of those links r workin
sorry, i wasnt able to find any links for the widcomm suite...looks like broadcom has discontinued support for widcomm devices
Old 17-11-2004, 08:25 AM   #9 (permalink)
How do i use the SP2 drivers when i plug in the device it says it is a USB device and nothing else.
About the links will try out now
Old 17-11-2004, 02:24 PM   #10 (permalink)
NONE OF THE LINKS ARE WORKIN !!??
Damn !!
anyways ill download the IBM drivers and use the HEX editor and upload it i guess ... thats the only way
whoever needs it can try it too ..
im in office right now .. will go home and give it a shot
this link for IBM drivers are workin
http://www-900.ibm.com/cn/support/do...S/bthwxp1o.exe
dunno abt the others ... its a 20mb download tho so be careful
and get a nice hex editor and suggest me one to download @home !
theraven is offline
