Old 22-05-2006, 10:17 PM   #1 (permalink)
Default Urgent: System Restarts
Hai friends
i brought a new computer and the configuration is
Amd 64 3000 939 pin
Asrock 939NF4G
Ram 256*2
Hard disk Hitachi Deskstar 250 gb sata 2
Problem:
my computer restart when i am doing task such as copying, playing games,installing etc or sometime it get hang.after it restarts the windows say ur system has recovered from serious error.it is restarting every time i boot.
i thought it will be because of overheating(i havent done overclocking)so i moniterd the bios the processor temperature is some what abt 49-51 range but its not exceeding it(is it a normal temperature ??)
and also when i boot in the morning the same problem exists but its is cold at that time.
please tell me what i need to do for ths problem.and i dont know if it is because of overheating..
is there any software in which i can see the processor temperature crossing the limit
waiting for ur response..thanx
maximus is offline
Old 22-05-2006, 10:55 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: Urgent: System Restarts
anything upto 59 is normal
hav u enabled cool & Quiet???it will take down some temp
i use v-center for checking temp i have a msi mobo don't know if it works for u
[edit]take a look here
gary4gar is offline
Old 22-05-2006, 11:13 PM   #3 (permalink)
yaa i have enabled cool and quiet
maximus is offline
Old 01-06-2006, 02:00 AM   #4 (permalink)
MegaD3th3K's Avatar
Yeah, i experienced something like this once. If it is really urgent, boot into SAFEMODE try copying, installing etc (no games in Safemode). Worked for me. Does stuff you copy from your CD/DVD/HDD drive get corrupt too? Then i think the prob is with your RAM. I know mine was. Got it changed and works fine now. I am no expert. I'm just telling by experience.
MegaD3th3K is offline
Old 01-06-2006, 09:23 AM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yes.. Gotta be a faulty RAM module.
kalpik is offline
Old 01-06-2006, 09:24 AM   #6 (permalink)
Ishan's Avatar
If Ram is having some problem, is it OK to take it out and reinsert it and then see the results?
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 01-06-2006, 09:29 AM   #7 (permalink)
kalpik's Avatar
Yes, you can try that.. If that doesnt work, try borrowing a module from a friend and try that!
kalpik is offline
