View Poll Results: Did U know this?
Yes 2 28.57%
No 5 71.43%
Voters: 7. You may not vote on this poll
Old 14-11-2004, 06:41 PM   #1 (permalink)
Default Convert Ur Single Layer DVD RW Drive Into Dual Layer
hey guys,
do u all wanna know how to convert ur single layer dvd writer into a dual layer one
then go this website:
http://codeguys.rpc1.org/index.html
http://codeguys.rpc1.org/oc.html
I have just converted my LITE ON 12x Single Layer DVD RW (Model SOHW 1233s) into a 16x Dual Layer(Model 1633s)
If any problems pliz let me know , i would help if possible or will others as there are a lot of gr8 guys in this forum
bye
Supratim
REGENADE:
The Real Character In you Always Shows Off
regenade is offline
Old 15-11-2004, 02:26 PM   #2 (permalink)
May not be possible to do this for all dvd drives, only drives with the latest tech. can be upgded
( Akshay please change your avatar / size. Its much above the forum limits - [deXter])
^ I wrote this!
akshayc is offline
Old 15-11-2004, 02:29 PM   #3 (permalink)
check out the article on this at tomshardware.com
^ I wrote this!
akshayc is offline
Old 16-11-2004, 12:43 PM   #4 (permalink)
Bewitched!
xenkatesh's Avatar
Its fully Hardware matter dude how can be able to do this with a software!!!??????????????????
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 16-11-2004, 12:46 PM   #5 (permalink)
Like the man said its not possible with all DVD drives only with the ones which have the HW already present and only needs a firmware upgrade.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 16-11-2004, 10:03 PM   #6 (permalink)
Default Surely u can upgrade
Hey guys,
u dont seem to believe that i have converted by Single layer DVD RW(LiteOn SOHW 1233s ) into a dual layer one 1633s model
well its works with most lite on drives , and also on some sony drives as well many other OEM drives as LITE ON is an OEM manufacturer & supplies DVD RWs to many OEMS like DELL,IBM & the SONY DVD RW is a rebagged one only , see digit nov. for that.
any refer to the above site that i mentioned in my starting post for details
bye
Regenade
REGENADE:
regenade is offline
Old 19-11-2004, 05:15 AM   #7 (permalink)
I have lite On Sohw-1633s in the web site you mentioned it says it can upgraded to Sohw-1653s. Is it Possible?
After flashing your firmware has writing quality improved?
shivaranjan.b is offline
Old 19-11-2004, 10:00 AM   #8 (permalink)
@akshayc
m8 kindly change your avatar.
It's too big.
Simple things are to simple too understand.
Prashray is offline
Old 14-04-2007, 05:27 PM   #9 (permalink)
harikatt's Avatar
Default Re: Convert Ur Single Layer DVD RW Drive Into Dual Layer
yes,, its not possible in old drives,, but only in the new,, where firmware upgradation possibility is there.
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
Old 14-04-2007, 07:01 PM   #10 (permalink)
gooby pls
Third Eye's Avatar
^Did you see the thread date ?
Third Eye is offline
