Old 21-05-2006, 03:55 AM   #1 (permalink)
Cool help needed urgent.....Ram
hi all
i am having 256Mb of Ram @266Mhz planning to buy 512 Mb@333 (on monday22 may) . can i use 333 and 266 at same time or u advice me to just use 333Mhz Ram .My 256 Mb is hynix please suggest me what to do and which comp ram to buy
my mobo do not support speeds greater than 333Mhz
thanks in advance
Hermit
hermit is offline
Old 21-05-2006, 12:27 PM   #2 (permalink)
digiFriend's Avatar
Default Re: help needed urgent.....Ram
if you use 333MHz ram with 266MHz, your new ram 333MHz will work only at 266MHz speed. ( ram speed is decided buy the lowest speed ram you are using) .
buy 333MHz ram and try to sell that old ram to the dealer. In most case dealer adjust that money in new ram which your buy from him
you never know what you can do until you try
digiFriend is offline
Old 21-05-2006, 12:32 PM   #3 (permalink)
phatratt's Avatar
the ram will scale down its speed to 266mhz.Hynix brand is OK,offers decent performace and quality,other brands u can try kingston,they are affordable too.
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 22-05-2006, 03:34 AM   #4 (permalink)
thanks a lot m8s for ur valuable suggestions .
hermit is offline
