Old 20-05-2006, 01:35 PM   #1 (permalink)
Default Spybot S&D - Problem
Am using winXP Pro SP2.
Regularly run microsoft AntiSpyware Beta 1, Spybot S&D 1.3 and Spyware Doctor.
Today whilst running Spybot S&D it reported the following one problem :
+ Windows.Explorer
HKEY_USERS\DEFAULT\Software\Microsoft\Windows\Curr entVersion\Policies\Explore\NoClose=W=0
HKEY_USERS\5-1-5-18\Software\Microsoft\Windows\CurrentVersion\Polic ies\Explore\NoClose=W=0
On clicking Fix Problem it gives message 2 problems fixed with a ?
Runnin the program again the same result. Finds same problem and fixes problem with a question mark.
Please help me get rid of this entry which Spybot cannot and not reported by AntiSpyware Beta 1 and Spyware Doctor.
Should I delete this entry from the Registry ?
I look forward to hearing from you guys
Nariman
Nariman is offline
Old 20-05-2006, 02:04 PM   #2 (permalink)
shovik's Avatar
Default Re: Spybot S&D - Problem
the registry entries for spybot has been corrupted in your case. this is a common affair with spybot. and also don't go with microsoft's anit-spyware solution as its still in the beta stage.
uninstall spybot and run a good registry cleaner such as registry mechanic and clean the left over debris. then install ad-aware or spyware doctor for a stable protection..
if you need more help feel free to contact me at <deb_shovik@yahoo.com>
regards,
Shovik.
shovik is offline
Old 20-05-2006, 03:16 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Why not manually remove those entries from Registry!
Simply fire regedit and goto following keys one by one:
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\Cur rentVersion\Policies\Explorer\
HKEY_USERS\5-1-5-18\Software\Microsoft\Windows\CurrentVersion\Polic ies\Explorer\
And remove the value NoClose
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 20-05-2006, 10:22 PM   #4 (permalink)
selva1966's Avatar
Many people fear editing registry manually, including MYSELF.
It it better to utilise the services of System Mechanic or TuneUp utilities etc., if you have them.
WHEN THERE IS LIFE, THERE IS HOPE...
TILL THERE IS BREATH, THERE IS HOPE
Give free food with one click to a poor Indian.
http://www.bhookh.com/
selva1966 is offline
Old 21-05-2006, 07:32 AM   #5 (permalink)
Distinguished Member
anandk's Avatar
update to spybot 1.4 and scan.
and then pls revert.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-05-2006, 03:56 AM   #6 (permalink)
__Virus__'s Avatar
one question which I always wanted to ask.. dono wtf is up with explorer policies or spybot.. that biyatch comes up again n again with same crap in the results
__Virus__ is offline
Old 22-05-2006, 03:57 PM   #7 (permalink)
Microsoft MVP
U can simply add those entries in Ignored items!
So next time Spybot will not show them in the result...
Old 22-05-2006, 08:16 PM   #8 (permalink)
I have been using Spybot for the last two years, updating it whenever new version is available and scanning using it at least once weekly. It never detected anything. BTW I surf the net for 1-2 hours everyday. Is it normal? (My XP is also always updated.)
V.Prem Kumar
janitha is offline
Old 22-05-2006, 11:00 PM   #9 (permalink)
Microsoft MVP
Very normal...
Don't worry!
Old 23-05-2006, 06:40 AM   #10 (permalink)
anandk's Avatar
yep. dont worry. addtitionally install spywareblaster
from http://www.javacoolsoftware.com/spywareblaster.html
Microsoft® MVP
anandk is offline
