Old 20-05-2006, 12:04 PM   #1 (permalink)
deepgeek2's Avatar
Default Free Partition Manager
Can anyone tell me about any free & reliable partition manager which *actually* does something and not like the demos of the big names which only let you play with the interface and do absolutely nothing.
Even a trial version would do but it must work.
My needs are basic and i am not looking for advanced features.
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 20-05-2006, 02:07 PM   #2 (permalink)
shovik's Avatar
Default Re: Free Partition Manager
follow the below link:
http://www.ranish.com/part/
this is one of the best available free partition utilities.
regards,
Shovik
shovik is offline
Old 22-05-2006, 01:17 PM   #3 (permalink)
deepgeek2's Avatar
Exclamation Re: Free Partition Manager
Hi! This tool is too advanced.
Isn't there a bit simpler Partition Manager?
Old 22-05-2006, 02:24 PM   #4 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Try BootIt NG. It is trial only if you install it, but if you run it from the floppy or CDROM, it easily resizes, formats and back-ups partitions.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 22-05-2006, 06:28 PM   #5 (permalink)
deepgeek2's Avatar
That's great.
But can it CREATE partitions?
Old 22-05-2006, 07:22 PM   #6 (permalink)
vignesh's Avatar
You can use the Partition Manager that is windows itself... Type gpedit.msc in the run prompt
vignesh is offline
Old 22-05-2006, 07:30 PM   #7 (permalink)
deepgeek2's Avatar
"File Not Found"
Pleas don't throw rotten vegetables at me when i let you know that i am still using WIN 98 SE
Old 22-05-2006, 08:32 PM   #8 (permalink)
But "WIN 98 SE" is not seen anywhere in your post.
V.Prem Kumar
janitha is offline
Old 23-05-2006, 03:23 PM   #9 (permalink)
Level 96 Headbanger
Yes, it can create partitions. You will have to resize your existing partition (make it smaller) first, only then you will be able to create one.
Be sure to defragment your HDD before you boot using it.
Steam : DeathMetal
Old 01-06-2006, 08:53 AM   #10 (permalink)
Ishan's Avatar
i have win xp in C: drive now. BUt my e: still contains two hidden partitions of linux? what should i do? i want to delete these. as i wanna run only xp.
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 01-06-2006, 11:19 AM   #11 (permalink)
Use Extended Fdisk
http://gnuwin.epfl.ch/apps/xfdisk/en...l/xfd093en.zip
first delete the Linux Partations and then creat new out of them
Sharing Knowledge Expands Horizon... And Problems r solved
bikram_singhy is offline
